Making Excel pie charts / flow charts, etc
I'm not being big headed when I say I know my way around Excel fairly well - It was part of my daily job to use them and adjusting spreadsheets to show results / data was all OK to me. BUT, in all this time I've never had to display results in anything other than totals / sums / formulae on a spreadsheet, never using pie charts, with colour codes, etc.
Any chance of an easy guide to it, and what format the data needs to be in? i.e is it 50,20,5,25 - as long as the sum = 100.0. :confused: I need to show % cost of sales as well, compared to actual sales over a period which will be XX.X % figures. Assume I just need to show it on a 0 - 100 Y axis scale.
:thumbup:
Excel can work out percentages even if the actual numbers don't add up to 100...though if you're actual figures are percentages then it would be a bit worrying if they didn't add up to 100... ;)
Easiest way to do it is just to highlight the cells you want to chart, and click the button on the top bar which is a small graph (on mine - Excel 2003 - it is a bar graph with a blue, yellow and red bar) - this will take you to the Chart Wizard, in which can just click about at various things until you get what you're after...
Rob.
:thumbup: Cheers Rob
Just been playing with the Excel "insert chart" function, and as you say - It seems easy enough to work with. Just will have to wait to see how it works in practise with the core data I'm analysing.
As every 6 minutes of my time has to be accounted for on an electronic time keeping bit of equipment, I'm sticking down 18 minutes to this client for my own training time. ;)
one more little tip - just select the data then press F11 :)
Once you have your graph you can then manipulate it as you will, using the toolbars and chart menu....
