Scuttle drains?
Hi Everyone
been following the pan roof leak fix and think I’m almost there.
after wet vaccing around 2 litres of very dirty water from the foot wells they are noticeably drier.
however I still occasionally get a small amount of condensation on the windscreen.
i was thinking that as the car is very old the scuttle drains may need a clean.
can anybody tell Me where they exit the car?
Dunk
Until the carpets are 100% dry you will be getting condensation.
Same problem, 2012 yeti with sunroof. I found putting a bathtowel in the floteell and jumping up and down on it extracted a lot of water too. I went through a lot of towels before the stopped soaking up water. The windscreen is still misting up overnight, but less and less.
I made the mistake of opening the sunroof to air the car. Lots of groaning from it, and then it stuck in the tilt position getting it closed. Looked in our invaluable forum, and found the advice to look at page 40 of the handbook. It explains how to invoke the emergency override to close the sunroof when the safety switch cute out the motor. It worked.
I figured the water in the passenger footwell must have come through the sunroof. Nothing on the drivers side though.
