Electric diagram parking aid
Hello. It's someone who can help me with diagram of  front parking aid 3u0 919 283 B? I want to make retrofit for front/rear parking sensors and I can't find electric diagram.
Thank's
According to my copy of the dealer wiring diagrams the MK1 Superb only had rear parking sensors not front ?
This is install on superb 2002-2008
Yes a MK1 the diagrams only show rear parking sensor system not front
This option is very rare, I try 2 years to find this computer who know about front/rear parking sensors. I will try without diagram
I have found the diagrams needed to put in a late MK1 details as it seems they were only available on post 2006 models
Mk1 Superb FnR Parking Sensors.pdf
You save me. Thank you very much
I don't understand one thing. Connector from button T4z/3 ro/gn need connect to 5. Do you know is that 5?
The #5 refers to the current tracks along the bottom of the diagrams, so if you go to the first diagram you will see at #5 follow that line up the diagram and it shows the Red/Green wire and a #52 and #52 refers you back to the diagram with T4Z/3
So from D(ignition) I need to go with one wire to T16f/3 J446 and T4z/3?
You might find the connector T3t on the Right side "A" pillar and from that run wires to those two connectors you mentioned
I undersand. Thank you for helping.
