Audio install
Hi everyone hope you're all well and good. I'm in the process of installing sub/amp. And struggling to find a remote output for amp and high level converter. All help much appreciated
what did you intend to install and how do you want to go about it?
 - Bret
Hi Bret,
Thanks for the reply
 I've managed to sort out and ignition feed for the amp remote so all good. All I've done is fit a high to low level converter so I can use a KAC -PS4D amp to power an L5 kicker and some front speakers. Now it's all working I've found out the standard fronts cannot take the power so I'll be replacing them quite soon. Would they be 17cm and would it be better to run components or just a decent mid range speaker?
Many thanks
Shaun
