Hot starting problem
I have Skoda Octavia automtac gear 1.6 cc
I have hot starting problems when i start it after 15 to 25 minutes of stoping specially in hot summer
I made full maintannce and i stil have this annoying problem
Help
@iSSA
You have posted in the past about cold start problems and the gears, and now hot start problems, so which country are you in and how hot is it you are talking about?
All of them were solved, but this problem is hard to detect i live in Damascus and the weather this days is about 38  degree in the noon
The problem was not the gear then it was the the cam shaft position sensor fault makes the car not shifting, the cam shaft has changed and the problem was solved
