Window regulator strange behaviour
Hi,
I had to change the battery in my octy(I was able to do it easily, without the radio reset) and realised that for some reason the drive(left) side window regulator is working differently than preciously. The automatic closing function when I pull the lever is disappearing and only lifting the window until I am pulling. The passenger side has this functionality. Previously both had this feature. Could it be a setting that has been deleted?
thanks
There is a procedure to remember this auto close feature, hopefully nothing broken
I believe part of it involves holding the window closed with button until you hear a click and perhaps the same in open position. Then the one touch comes back. Someone will be along soon with a proper explanation.
The auto function can be reprogrammed, just open the window and close it holding the switch for another 5 secs after fully closed.
It should then be OK.
Thanks both of you. It is working now. It was only necessary to kepp it holding
