Clutch Help
Alright chaps.  Got an issue with 07 vRS clutch.
The pedal goes down and I can get the car in gear.  The pedal doesn't return.  If I lift it up with my foot the clutch engages.
Obviously this makes driving impossible 🤣
Master cylinder?
Almost certainly.
3 minutes ago, sepulchrave said:
Almost certainly.
Ta mate
Any point to bleed the system first or check if slave is leaking?
VRS uses a concentric slave hidden inside the bellhousing, much easier and cheaper to replace the master and bleed the entire system.
