skoda fabia classic 1.2
hi,the engine makes a strange noise,when pushed,in,and wont go in to gear,i have cheeked the clutch fluid.
it was a bit low,topped up,tryed to blead ,(60 times)still no fluid came out,i could feel the flexy pipe,sweel up,when peddle was pushed down, has any 1 else had the same problem,or dose any 1 else known,what the problem is,its done 70,000 miles ,any help would be much appreciated, thanks
  • Sponsor
For some reason,  I find that you have to loosen the clutch bleed screw a lot further than a typical brake caliper one before any fluid starts to flow.
