Multifunction Steering wheel (non virtual cockpit model) Confusion
Hi All - I have the standard (non-virtual cockpit) display and am having a nightmare with getting the view to change the way I want it to.  I also have ACC.
Normally, when driving, I have the display in the centre set to show the current speed but sometimes I want to quickly show the Phone display.  This seems to work okay and I can flip between the two by clicking "View".  The trouble starts if I hit the ACC (Assistance systems) button. Once I have done this (just the once) the view button seems stuck in a look between the "Assistance systems" screen and the "Speed" (or whatever item I have selected).  I can from that point forward no longer flip between the phone display and my selected "other bit of data" display.  What I would like to do is have the system forget the fact that I may (some time ago) have looked at the "Assistance Systems" screen and go back to the flip between "Speed" and "Phone"   I just can seem to get it to understand that I don't want to see ACC when I clikc "View".    Its driving me silly.  If, when "ACC is Inactive" is displayed I use the B button to scroll to, say "Phone" and click to select it it will display the "Phone" If then click "View" it takes me back to the blasted "ACC is Inactive" aka "Assistance System Menu" rather than the "Spee" that I want to see.   Grrrrrrrrr.
This is the manual.  This bit in yellow says what its meant to do :
Can someone please explain what I'm doing wrong?
Cheers,
Paul
OK I think I sussed it.   When you click "View" it flips between the last two selected options you have chosen to view in the main display window.  If you are stuck in "ACC" menu as you second choice then you have to go into the main menu, select the first one you want (e.g.  Speed).  When speed is displayed you then have to go back into the main menu and select the second one you want (e.g. Phone).  Then phone is displayed and when you click "View" it flips to the prevoius choice of "Speed".  If you ever click on ACC button then this becomes the last menu selected and you have to do though and do a new "double selection" to get it back to where you want it.
Edited by smipx
