Electrical gremlins
Lovely car but a few irritating electrical gremlins that the dealer needs to fix.
The tyre pressure sensor comes on every drive and needs resetting each time and the gear change indicator display is having a disco constantly flickering on and out and showing random gear change numbers. Hopefully an easy dealer fix but anyone else had this?
Tyre pressure sensor YOU HAVE A SLOW PUNCHER only needs a slight drop in pressure not that you would notice get your tyres checked.
Thanks wondered about that and it would mean it came like that new from dealer although I’ve checked daily and no change so far but I’ll ask dealer to also check.
@ima
Just out of interest but what were the Tyres pressures at as you received the car after rhey had PDI'd it?
They were 40 psi rather than recommended 36.
If you need the tyre pressures they are in the petrol cap behind the ice scraper
