Rear view camera glitch
Hi, I used to have a Bolero system then I changed it to Columbus MIB2.5 retrofit. My problem is with the car icon while using the rear view (rear gear). There are two black spots near the front plate (left, right) always.. Also sometimes but sometimes, the car icon part is blank ( black rectangle) for 3-5 seconds then back to normal. Before changing the unit I had the black rectangle issue but not the plate one. Now I have the plate issue but almost no black rectangle issue. I need your help. Thanks.
P.S:  I saw an other retrofit car same model with mine and it didn't have any visual issues. They tried coding again but didn't help. I will put the photo here.
Does anyone have any idea ? Is it a software or a hardware issue ?
I'd suggest finding an autoscan and adaption maps for a similar car with it working.
You can then compare to yours to see what differences there are. It should help you find out if it's software, hardware or configuration.
Thanks for your reply, as I understand it impossible for me the understand because I don't have the kits and the person who made the installment just don't understand this stuff. Maybe but maybe if I tell him "this must be the broken thing please check it" then it may work. Thanks again.
