Could not do it if I tried!!
I’ve just managed to lose a micro sd card beneath the electric handbrake switch 😳
at first I almost got it back and the switch was sticking but it dropped fully down and the switch works fully again.
could I access it if I removed the cup holders? Or do they even come out??
I am great at removing things but fairly sh1te at putting them back together.
Can’t help you there but I feel your pain - I managed to get the usb connector from my VCDS lead wedged in between the drivers seat guide rail and the door trim the first time I used it and removed the plug from the diagnostic port and it took me ages to get the damn thing out! Good luck removing your sd card, I reckon you’d be easier to cut the losses and buy another unless it has irreplaceable data on it?
Ouch, and cheers for the reply, nah it’s a cheap replacement and nothing of importance on it.  Just anxious in case it causes interference with the electric handbrake.
I don’t want to risk damaging the piano black surround so I may just let it be.
Judging how easily I destroyed a 64gb micro sd when taking the back cover off my daughters Amazon fire tablet a while back without removing it I’d be surprised if one was capable of doing any damage down there. More likely to just get munched up and forgotten about.....
Yeah that’s what I was thinking.
I’ll probably just replace the micro sd card.
Thanks again 👍
  • 3 months later...
