What laptop?
I require some help:confused:
I would like a laptop that needs only to do the following,
1; be able to connect to the internet through wifi:confused: without cables,as I have broadband on my "main computor" which I can plug a router in.
2; be able to play DVD's on.
3; Hopeing to get a plug in TV tuner so i can use it as a TV / DVD player in the caravan.
Thats all i need it for as everything else is done on the main computor, hope that makes sense.:confused:
Virtually all new Laptops these days will do that if you add an external USB TV Tuner like the Freecom DVB.
Main question is what is your Budget?
Cheap as poss:rofl: upto
Here you go.
£368 for the laptop with a widescreen display and DVD writer , then buy a USB tv tuner from Ebuyer.
Oh , and you'll need to select the 1 year warranty instead of the 3
Intel® Celeron® M 370 (1.50 GHz, 1MB L2 Cache, 400 MHz FSB)
Windows® XP Home Edition
512MB 533MHz DDR2 SDRAM
40GB (5.400rpm) Hard Drive
15.4" WXGA (1280x800) LCD Panel
8X DVD+/-RW with Software
Internal 56K v.92 Capable Fax Modem
Dell™ Wireless 1370 802.11b/g Mini PCI Card
http://configure.euro.dell.com/dellstore/config.aspx?c=uk&cs=ukdhs1&l=en&oc=N04135b
Also worth a look at Dell Web Site they normally have some good offers on. General rule of thumb is to go for the best you can afford, Centrino Processor, Minimiun 512MB RAM with spare slot so you can upgrade later if required without binning the existing memory, and as big a hard drive as possible especially if you want to record TV or DVD's.
Graphics Card shouldn't be an issue as long as you don't want to play games on it as a lot of mid range Laptops will not run the latest games.
Thanks for the advice guy's. Will investigate:thumbup:
Here you go.
nebula digitv usb box is very good , about £86 from nebula ,or off ebay i just paid £60 inc postage ,approx 10 minutes to load software and find all the stations available and you can record up to 7 channels at the same time (on the same mutiplex) HDD space allowing , its about 5" by 3" box and comes with a remote control
Thanks again, Have bought a Fujitsu with the above spec. so very happy.Afew questions to ask, in new thread.
