Heavy condensation on inside of windows
Hi Guys
Just a quick update. Skoda just called to say that my car will be a while yet as they are not sure where the leak is. No surprise there !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
They don't want to take the screen out until they are absolutely sure it is the problem as warranty won't pay them for it if it turns out to be something else.
  • Replies 50
  • Views 10.7k
  • When it happens if there are no traces of leaks or damp carpets, if the previous journey the occupants were not wearing wet coats & if the aircon was on when the engine stopped & the moisture
  • Normally the air dryer in the air conditioning will remove moisture from inside (unless you daftly turn it off).   In same way fog forms, colder air cannot hold as much moisture as warmer ai
  • During the floods, did you drive through water six inches deep?  If you leave a heavy weight on the carpets, does water appear?  I suspect you have a lot of water under the carpet, maybe in the rear.
