Increase the brightness of DRL strips when used for CH/LH
Hi Guys,
I followed this old thread to deactivate my low beams and leave only the DRL strips for CH/LH function. It's a pre-FL O3 2016. The adaptation instructions below works great, but the DRL strips during the CH/LH aren't as bright as when the car is running. Is there anyway I can get the same brightness level of this strips for the CH/LH function like when drive the car? There should be VCDS setting about it :)
I'm using the following adaption from this post( the rest is the default settings ):
Quote
CH/LH lights changed from dipped beam to DRL's
(8)-Leuchte6ABL LC5-Lichtfunktion C 6 - left as active
(8)-Leuchte7ABL RB1-Lichtfunktion C 7 - left as active
(10)-Leuchte6ABL LC5-Dimmwert CD 6 - value change from 127 to 0
(10)-Leuchte7ABL RB1-Dimmwert CD 7 - value change from 127 to 0
(11)-Leuchte6ABL LC5-Dimming Direction CD 6 - change to minimise
(11)-Leuchte7ABL RB1-Dimming Direction CD 7 - change to minimise
Thanks in advance!
