Starter button sticking
The starter button has become a bit erratic sometimes taking 2 pushes to start or stop. The car is April 2015. Would it be safe to squirt a little WD 40 on the button or I have an aerosol can of silicon spray which may be safer Joe
You more than likely need a new switch.
Thanks for the information. I will get in touch with the garage I use Joe
Independent garage has fitted a new switch. Can feel the difference after a couple of stop starts. Cost for parts and fitting £125 Joe
Sounds very reasonable. :) :thumbup:
Dread to think what the main dealer would have charged. It’s only a small independent  garage but they are really good they sorted out a problem with my turbo charger. I suspect the main dealer would have fitted a new one.
Less than £100 all in. They take about 5 minutes to fit and the part is only £35 quid.
 i had same issue ,  i prised off the silver ring around the switch and blasted into it all around with contact cleaner a few times over a day.
seemed to have fixed the issue .
Edited by dadumtish
Fitting was 1 1/2 times the part cost. For a 5 min pop out push in job. 10 year old could fit one
