Bushes
Greeting to all. My gear lever is increasingly showing more slack in the bushes / linkage. Is a known issue ? Had a quick look internet but price of full bush kit expensive.
After some research I think the following bushes / bearings could have worn :  2 x Bowden catches ( 8 or 10 mm) ? 2 x lower cable gear lever bushes ( fiddly)  maybe gear lever bushes. Probably a main dealer trip to get correct ones
  • 2 months later...
My mechanic sprayed the gearbox linkage with lubricant. Cured the fault
