PD 105 BKC possible injector/harness fault but no DTC?
I'm trying to fix a rough running engine when cold and under load.
I'm still diagnosing it as a potential fuelling issue, restriction/air ingress but I was wondering if it was the well known injector harness problem where the electrical connectors become loose.
Could this happen without triggering a DTC?
I don't have VCDS but a similar tool and will check block 13 to see if there is an injector out of line.
Is there anything else I should check before lifting the cam cover for a check of the harness.
The rough running only happens when the engine is cold and under moderate load, clearing within a couple of miles.
FIXED:
