Sat Nav Issues
Good evening, I am new to this site so bear with me if this has been raised before. I posted this on the site but not on this section. Was advised this would be the better place to post.
I have a 2017 vRS TDI and my wife a 2017 Fabia.  We both have Sat Nav but hadn't upgraded them since new.  However, I now wish I hadn't bothered.
I went to the portal, followed the instructions saved the contents of the SKODA SD card and then formatted the card.  I then downloaded the new maps (approximately 13Gb) and transferred the new maps on to the card (16GB).  Feeling pleased as punch went back to the card to see a message along the lines of "No navigation data".  This was for both cars.
I DM'd SKODA to be told that I would need a 32Gb card and that I would have to but them from a dealer.  Contacted the dealer, they say I must buy 'pre loaded' cards at a cost of over £250 per card!  Went back toSKODA to ask about blank cards to be told I would have to buy the 'pre loaded' ones.
I then tried to re-install the old maps and guess what......?!
I now have two cars with Sat Nav that cannot be used.  Any advice or guidance will be greatly appreciated.  I use a MacBook Pro if that is of any interest.
The latest maps still work perfectly on a 16GB card :)
Your macbook will be causing problems as macOS tends to add extra files which confuse the satnav. If you can, I'd suggest trying again using windows?
If not, I think it's possible to clean the SD card and make it work - I'm sure there is a guide somewhere...
