Included Schuko charger with the iV
Hi fellers,
I've been using the included Schuko charger cable on 10A outlets so far.
I have found that there actually are some public 16A Schuko chargers in my city.
Will I be able to charge 3,7 kW on these with the included charger cable?
Best regards
Oskar
Hi,
I do not think so as the charger will limit the current to 10A as it has no idea what it is plugged into.
If you use the type 2 cable in a proper charger you will be able to get the max charge rate (still limited to 3.6Kwh)
Or if you have a fitted charge point at home but the max 3.6 still applies.
john
2 minutes ago, jjc said:
Hi,
john
I understand, thought maybe it would work with some amount of magic.
So to be able to charge 3,7 kW/16 A via Schuko i would need a cable with the option to switch between 10 A and 16 A which i suppose the included cable is not capable of.
Correct,
you can get some on eBay or Amazon but the supplied cable is fixed
John
