Another Infotainment Question
Hi, I’m replacing my old head unit (5Q0035840A) with a Columbus min 2.5 (565035021C) and need help with two connections at the back of the head. The pink and yellow plugs on the original wiring won’t connect to the yellow and grey ports on the unit. Do I need to buy adapters or new cable to the screen?
Thanks in advance
Cormac
@SashaGraceshould be able to help with this one she has done many mods including this on her Vrs Estate.
If you take a closer look, you probably just need to trim the fakra keying down so they'll fit :)
What are FAKRA Connectors? - everything RF
That’s great info, wanted to ask before I started hacking. Cheers
