Mk1 octavia estate audio question (probably polishing a turd...)
Hello,
Been lurking about here for a while and wondering can anyone help with the audio in my car.
I have tdi mk1 octavia estate (20 years old in March) and appreciate the best answer is probably:  buy a new car; but it won't die and I'm loathe to get rid of it.
Anyway...
Audio is currently completely stock. Speaker in the passanger door has died. It crunches when I push the cone suggesting the voice coil has gone and I need to set the bass to -2 so it doesn't distort.
I can find s/h replacements on ebay for pennies but I'm curious what I could do by way of upgrades, any second hand driver is gonig to be at least 16 years old by now and will probably fail soon, I think my other, in the driver door, is on the way out too, it distorst at moderately high volume.
I have the following bits lying aroung and on the way:
  • 2 unused old sony xplod coaxial 6x9s (probably useless, can't see how i could fit them)
  • New head unit, 4x50W: one of theses I found for sale locally
  • one of these Magnat rock 6000 amps that I stumbled across on an auction site for very little money (4 x 85/200W RMS/peak)
I've read this: https://uk-mkivs.net/topic/14927-how-and-why-to-change-your-mk4s-speakers-updated-10809/
Which gives the impression that the best thing to do would be to put in the new head unit and replace the speakers like for like.
But that seems a bit boring
Thread here suggests good results from an amp: https://www.briskoda.net/forums/topic/480242-custom-fitstealth-audio-upgrade/
So a few questions:
  • Any point replacing the door speakers with anything other than stock?
  • Anything I can do with the 6x9s?
  • Is it worthwhile amping the new head unit?
  • Is it worthwhile damping the doors?
  • Any left of field ideas?
A random idea I had was to get a hold of those slim BMW floor subs (like these) and stick them in the boot. I have a levelling kit which gives a false floor and kind of useless space underneath. I don't want a big sub box. Thought I could send some bass there instead of the front
I do a fair bit of electrical work and a bit of tube amp work so I'm happy with the technical parts of this
Cheers!
  • Administrators
This is something I’ve been looking into. I found a simple (decent) head unit made a hell of a difference, even with the standard speakers. I upgraded the front with some spare components I had laying around (never used) and that improved things even more. I thought about the corner rear boot stealth sub and upgrading the rear 6x4s for improved sound. I have yet to get round to the sub, but my next upgrade will be the rears and I think I’ll be going for some rockfords. I’m going to try these and see how they sound and I may possibly amp them to improve further. But right now I’ve just replaced the HU and front speakers and they sound decent.
Edited by DeanVRS20VT
Cheers,
Any problems installing the other speakers? Did you do anything with the tweeters of the crossovers?
  • Administrators
52 minutes ago, gilmo said:
Cheers,
Not in my estate, I just left it with components. However, in my VRS I did the full setup with crossovers and tweeters. The unit is inside the door panel and the twitters are standard size to they fitted straight in.
There no issues fitting the speakers as long as you get the correct size, there should be a topic that Rob made about the right size/depth.
