Gear Slipping
Hi all,
Just wondered if anyone has experience  of the following. I have a 2020 Karoq, 1.5 manual. A few times now when stationary in traffic, in first gear with clutch down, as I go to pull off the gear slips into reverse! Nearly caused a few little accidents and losing confidence  when in traffic.
You must be pushing down on the gear stick and selecting reverse when you think your going into 1st. If you do inadvertently select reverse the PDC should come up on the display and you should also hear a bleep.
Thanks Kenny, will go out again this weekend and observe. Not confident this was the cause. Thanks.
