Changing DRL bulb in halogen headlights to LED
Although what is written in the title is not entirely my case, it should help. So I put an aftermarket headlights into my car and now on the pin where used to be halogen daytime running lights is LED strip. Can somebody please share coding for changing DRLs bulb to LED, so I can get rid off error message on dashboard?
Thank you.
Can you post an autoscan and adaption map for 09?
@langers2k sure, it took some time, but here it is:
09 Central Electrics
    System description: BCM MQBAB M
    Software number: 5Q0937084AG
    Software version: 0137
    Hardware number: 5Q0937084AG
    Hardware version: H18
    Serial number: 01011509100259
    ODX name: EV_BCMCONTI
    ODX version: 013000
    Long coding: 0C001842424702FB47E04000000407080000000000000000000000000000
    Subsystems:
        System description: WWS371 150325
        Software version: 0570
        Hardware version: 041
        Serial number:         150328054715
        Long coding: 065DDD
        System description: RLHS
        Software version: 0059
        Hardware version: 037
        Serial number: S4Y15M04D09H23M23S58
        Long coding: 00885D
    Trouble codes:
        No trouble codes found
So anyone who can help me please?
Have you got the adaption map to go with that?
@langers2k Can it be done with obdeleven? I don't have VCDS.
Not sure, I've never used OBDeleven.
I think a backup of the BCM might have enough information included :)
@langers2k OK, so I did what you asked for. Hopefully it will have enough information.
Backup
    Control unit: 09 Central Electrics
    ODX version: 013000
    Backup name: bcm9
    Long coding:
    Adaptations:
        Driving light and parking light:
            Kontrollleuchte fuer Begrenzungslicht:
                integriert in Suchbeleuchtung
            Schlusslicht mit Bremslichtfunktion:
                not active
            Standlicht aus:
                active
            Parklicht ueber LSS aktiviert:
                One-sided
            Standlichtreduzierung mit beidseitigem Parklicht:
                active
            Zahl der aktiven Scheinwerfer auf 2 limitieren:
                in Betrieb lassen
            Warnung Fahrt mit Standlicht:
                not active
            Zeitwert Einschaltzeit Abbiegelicht:
                15 min
            Lichthupe bei Zuendung aus moeglich:
                active
            Lichtwarnungsverhalten:
                klemmenabhaengig
            Menueeinstellung CHO LHO:
                Menuesteuerung Zeit aktivieren
            Allwetterlicht Einschaltgrenze:
                50 km/h
            Allwetterlicht Ausschaltgrenze:
                50 km/h
            Nebelschlusslicht Warngeschwindigkeit:
                0 km/h
        Transport mode:
                active
        Read parameter address:
                0
        Deactivate production mode:
                not active
        Auxiliary functions:
            Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT:
                not active
            Spoiler Einfahrunterdrueckung nach manuellem Ausfahren:
                not active
            Reserved_1:
                not active
            Signalhorn ohne KL15:
                active
            Klemmenfehler auf CAN ausgeben:
                active
            reserved_2:
                not active
        Anti-theft device:
            Alarmsignal:
                frequency modulated
            Verzoegerung Panikalarm:
                keine verzoegerung
            DWA Alarmverzoegerung:
                not active
            DWA Camper Modus:
                not active
            Ueberwachung Innenentriegelungshebel:
                not active
            Sirenen Alarmzahl:
                10 Alarme
            Akustischer Alarm Signalhorn:
                not active
        Acknowledgement signals:
            Akustische Rueckmeldung entriegeln:
                not active
            Akustische Rueckmeldung verriegeln:
                not active
            Dauer der Akustischen Rueckmeldung vom Einfachhorn:
                kurz
            Optical feedback during locking:
                Decelerate
            Optische Rueckmeldung Komfortschliessen:
                not active
            Optische Rueckmeldung 3.Bremsleuchte:
                not active
            Menuesteuerung akustische Rueckmeldung:
                not active
            Akustische Rueckmeldung global:
                not active
            Akustische Rueckmeldung Signalhorn:
                not active
        Access control 2:
            Komfortbedienung global:
                active
            Comfort opening:
                active
            Comfort closing:
                active
            Komfortoeffnen nur FH Fahrertuer:
                not active
            Nachsaven_nach_Verdecklauf:
                not active
            Funk Komfort schliessen:
                active
            Funk Komfort oeffnen:
                active
            Reserved_4:
                not active
            Schliesszylinder Komfort schliessen:
                active
            SAD Richtung Komfortoeffnen:
                tilting
            SAD Komfort schliessen:
                not active
            SAD Komfort oeffnen:
                not active
            Freigabenachlauf FH bei Kl 15 aus:
                active
            Freigabenachlauf FH bei Tueroeffnen abbrechen:
                active
            Regenschliessen_ein_aus:
                not active
            Regenschliessen_art:
                once
            Spiegelabsenkung bei Rueckwaertsfahrt:
                active
            Spiegelverstellung Synchron:
                active
            Kessy Komfort oeffnen:
                not active
            Kessy Komfort schliessen:
                active
            Kessy Komfortbedienung Reichweitenbegrenzung:
                not active
            Menuesteuerung Spiegelabsenkung:
                active
            Funk Spiegelanklappen:
                not active
            Funk Spiegelanklappung Modus:
                by look command via remote control key
            Menuesteuerung synchrone Spiegelverstellung:
                active
            Menuesteuerung Funk Spiegel anklappen:
                not active
            Menuesteuerung Komfortbedienung einstellbar:
                adjustable
            Menuesteuerung Regenschliessen:
                not active
            SAD PreCrash Konturschliessen:
                not active
            FH SAD Kl15Aus Freigabezeit:
                600 s
            Fahrertuerbedienung Fensterheber oeffnen:
                active
            Fahrertuerbedienung Fensterheber schliessen:
                active
            Remote_Unlock_Lock:
                not active
            Profilfunktion fuer Anklappung der Aussenspiegel:
                not active
            Signalisierung_Spiegelanklappung:
                active
            virtuelles_pedal:
                not active
            virtuelles_pedal_HMI_einstellbar:
                not active
            Schliesszylinder Komfort oeffnen:
                active
        Access control:
            Funk bei Klemme 15 ein:
                not active
            Notschliessfunktion:
                active
            Automatisches Verriegeln bei Geschwindigkeit:
                active
            automatisches Entriegeln:
                active
            Geschwindigkeitsabhaengige Tankdeckelverriegelung:
                not active
            ZV Tuerentriegelung:
                Globale Entriegelung
            CAN Wecken bei Softtouchbetaetigung:
                active
            Wiederoeffnung Elektrische-Schiebetuer:
                not active
            Oeffnung Heckdeckel bei Wiederentriegelung:
                active
            Heckdeckel-Bedienstellen nachCrash temporaer sperren:
                active
            Valet parking:
                not active
            Direkter Auswurf des Heckdeckels:
                active
            ZV entriegelt auch Heckdeckel:
                active
            Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt:
                not active
            Autolock Autounlock wirkt auf Heck:
                active
            ZV Heck nur direkt auswerfen:
                not active
            Manuelle ZV Variantenprogrammierung:
                not active
            Wiederholte Heckansteuerung beim Schliessen FT oder BT:
                not active
            Schliessung der Schiebetuer bei geoeffneter Tankklappe:
                not active
            Bewusstes Safe mit 2. Betaetigung der FFB:
                not active
            ZV-Entriegelung nach Seitencrash:
                not active
            Entsafen mit autorisierte Klemme 15 Ein:
                not active
            Elektrische Laderaumabdeckung:
                not active
            Menuesteuerung Tuerentriegelung:
                active
            Menuesteuerung ZV Autolock-Unlock:
                adjustable
            Autounlock NAR:
                not active
            Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster:
                not active
            Softtouch-Betaetigung senden:
                immer
            Servoheck Schlossansteuerung:
                immer
            Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster:
                active
            Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang:
                not active
            Vorrastenhaenger_Freigabe:
                not active
        Windshield wiper:
            Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung:
                0
            SRA Verzoegerungszeit:
                0 ms
            SRA Waschzeit:
                0 ms
            SRA Einweichpausenzeit:
                0 ms
            SRA Nachwaschzeit:
                0 ms
            SRA Pausenzeit:
                0 ms
            SRA bei Waschwassermangel:
                not active
            Frontwischer Referenzlauf:
                active
            Variable Regensensoraktivierung:
                active
            Wischer stop bei KL15 aus:
                not active
            Wischer abparken bei Oeffnen der Motorhaube:
                not active
            Regensensor aktivieren:
                Deactivating
            Menuesteuerung Frontwischer:
                not active
            Frontwischer Notlaufprogramm:
                active
            Tippwischen mit erhoehter Wischfrequenz:
                active
            Geschwindigkeitsabhaengige Wischstufenrueckschaltung:
                active
            Traenenwischen Front Status:
                not active
            Washer_Tipwiping_Variant:
                0
            Adaptives Nachwischen bei SRA:
                not active
            Wischer Stopp bei Oeffnen der Motorhaube:
                not active
        Turn signal control:
            Warnblinken bei Verdeckentriegelung:
                not active
            Komfortblinken Blinkzyklen:
                3
            Sonderfunktionen:
                not enabled
            Signalprioritaet fuer Blinker:
                SMLS
            Blinkkontrolleuchte fuer Anhaenger:
                separte
            Warnblinktastersuchbeleuchtung Aktivierung:
                always active
            Komfortblinken:
                active
            Warnblinktastersuchbeleuchtung Grundwert:
                20.00 %
            Warnblinktastersuchbeleuchtung Faktor:
                0.10
        Production mode:
            Scheinwerferreinigung:
                not active
            Frontwischer deaktivieren:
                not active
            Heckwischer:
                not active
            Innenbeleuchtung:
                not active
            Aussenbeleuchtung:
                not active
            Zugangskontrolle:
                not active
            Virtuel_pedal:
                not active
        Light configuration:
            Lasttyp 0:
                12 - Blinkleuchten
            BAP Bitposition 0:
                34
            Reserved 0:
                0
            Fehlerort mittleres Byte DTC-DFCC 0:
                14
            Lichtfunktion A 0:
                2
            Lichtfunktion B 0:
                0
            Dimmwert AB 0:
                100
            Lichtansteuerung HD AB 0:
                always
            Lichtfunktion C 0:
                0
            Lichtfunktion D 0:
                0
            Dimmwert CD 0:
                0
            Dimming Direction CD 0:
                maximize
            Lichtfunktion E 0:
                0
            Lichtfunktion F 0:
                0
            Dimmwert EF 0:
                0
            Dimming Direction EF 0:
                maximize
            Lichtfunktion G 0:
                0
            Lichtfunktion H 0:
                0
            Dimmwert GH 0:
                0
            Dimming Direction GH 0:
                maximize
            Lasttyp 1:
                12 - Blinkleuchten
            BAP Bitposition 1:
                3e
            Reserved 1:
                0
            Fehlerort mittleres Byte DTC-DFCC 1:
                15
            Lichtfunktion A 1:
                4
            Lichtfunktion B 1:
                0
            Dimmwert AB 1:
                100
            Lichtansteuerung HD AB 1:
                always
            Lichtfunktion C 1:
                0
            Lichtfunktion D 1:
                0
            Dimmwert CD 1:
                0
            Dimming Direction CD 1:
                maximize
            Lichtfunktion E 1:
                0
            Lichtfunktion F 1:
                0
            Dimmwert EF 1:
                0
            Dimming Direction EF 1:
                maximize
            Lichtfunktion G 1:
                0
            Lichtfunktion H 1:
                0
            Dimmwert GH 1:
                0
            Dimming Direction GH 1:
                maximize
            Lasttyp 2:
                not active
            BAP Bitposition 2:
                0
            Reserved 2:
                0
            Fehlerort mittleres Byte DTC-DFCC 2:
                0
            Lichtfunktion A 2:
                0
            Lichtfunktion B 2:
                0
            Dimmwert AB 2:
                0
            Lichtansteuerung HD AB 2:
                always
            Lichtfunktion C 2:
                0
            Lichtfunktion D 2:
                0
            Dimmwert CD 2:
                0
            Dimming Direction CD 2:
                maximize
            Lichtfunktion E 2:
                0
            Lichtfunktion F 2:
                0
            Dimmwert EF 2:
                0
            Dimming Direction EF 2:
                maximize
            Lichtfunktion G 2:
                6
            Lichtfunktion H 2:
                0
            Dimmwert GH 2:
                100
            Dimming Direction GH 2:
                minimize
            Lasttyp 3:
                not active
            BAP Bitposition 3:
                0
            Reserved 3:
                0
            Fehlerort mittleres Byte DTC-DFCC 3:
                0
            Lichtfunktion A 3:
                0
            Lichtfunktion B 3:
                0
            Dimmwert AB 3:
                0
            Lichtansteuerung HD AB 3:
                always
            Lichtfunktion C 3:
                0
            Lichtfunktion D 3:
                0
            Dimmwert CD 3:
                0
            Dimming Direction CD 3:
                maximize
            Lichtfunktion E 3:
                0
            Lichtfunktion F3:
                0
            Dimmwert EF 3:
                0
            Dimming Direction EF 3:
                maximize
            Lichtfunktion G 3:
                7
            Lichtfunktion H 3:
                0
            Dimmwert GH 3:
                100
            Dimming Direction GH 3:
                minimize
            Lasttyp 4:
                9 - allgemeine Glühlampe 27W, auch H15
            BAP Bitposition 4:
                3a
            Reserved 4:
                0
            Fehlerort mittleres Byte DTC-DFCC 4:
                43
            Lichtfunktion A 4:
                8
            Lichtfunktion B 4:
                9
            Dimmwert AB 4:
                30
            Lichtansteuerung HD AB 4:
                always
            Lichtfunktion C 4:
                30
            Lichtfunktion D 4:
                0
            Dimmwert CD 4:
                30
            Dimming Direction CD 4:
                maximize
            Lichtfunktion E 4:
                20
            Lichtfunktion F 4:
                0
            Dimmwert EF 4:
                100
            Dimming Direction EF 4:
                maximize
            Lichtfunktion G 4:
                0
            Lichtfunktion H 4:
                0
            Dimmwert GH 4:
                0
            Dimming Direction GH 4:
                maximize
            Lasttyp 5:
            BAP Bitposition 5:
                44
            Reserved 5:
                0
            Fehlerort mittleres Byte DTC-DFCC 5:
                44
            Lichtfunktion A 5:
                8
            Lichtfunktion B 5:
                10
            Dimmwert AB 5:
                30
            Lichtansteuerung HD AB 5:
                always
            Lichtfunktion C 5:
                30
            Lichtfunktion D 5:
                0
            Dimmwert CD 5:
                30
            Dimming Direction CD 5:
                maximize
            Lichtfunktion E 5:
                20
            Lichtfunktion F5:
                0
            Dimmwert EF 5:
                100
            Dimming Direction EF 5:
                maximize
            Lichtfunktion G 5:
                0
            Lichtfunktion H 5:
                0
            Dimmwert GH 5:
                0
            Dimming Direction GH 5:
                maximize
            Lasttyp 6:
                11 - Abblendlicht
            BAP Bitposition 6:
                36
            Reserved 6:
                0
            Fehlerort mittleres Byte DTC-DFCC 6:
                1a
            Lichtfunktion A 6:
                11
            Lichtfunktion B 6:
                30
            Dimmwert AB 6:
                100
            Lichtansteuerung HD AB 6:
                always
            Lichtfunktion C 6:
                0
            Lichtfunktion D 6:
                0
            Dimmwert CD 6:
                0
            Dimming Direction CD 6:
                maximize
            Lichtfunktion E 6:
                0
            Lichtfunktion F 6:
                0
            Dimmwert EF 6:
                0
            Dimming Direction EF 6:
                maximize
            Lichtfunktion G 6:
                0
            Lichtfunktion H 6:
                0
            Dimmwert GH 6:
                0
            Dimming Direction GH 6:
                maximize
            Lasttyp 7:
                11 - Abblendlicht
            BAP Bitposition 7:
                40
            Reserved 7:
                0
            Fehlerort mittleres Byte DTC-DFCC 7:
                1b
            Lichtfunktion A 7:
                12
            Lichtfunktion B 7:
                30
            Dimmwert AB 7:
                100
            Lichtansteuerung HD AB 7:
                always
            Lichtfunktion C 7:
                0
            Lichtfunktion D 7:
                0
            Dimmwert CD 7:
                0
            Dimming Direction CD 7:
                maximize
            Lichtfunktion E 7:
                0
            Lichtfunktion F 7:
                0
            Dimmwert EF 7:
                0
            Dimming Direction EF 7:
                maximize
            Lichtfunktion G 7:
                0
            Lichtfunktion H 7:
                0
            Dimmwert GH 7:
                0
            Dimming Direction GH 7:
                maximize
            Lasttyp 8:
                10 - allgemeine Scheinwerfer
            BAP Bitposition 8:
                37
            Reserved 8:
                0
            Fehlerort mittleres Byte DTC-DFCC 8:
                1c
            Lichtfunktion A 8:
                13
            Lichtfunktion B 8:
                15
            Dimmwert AB 8:
                100
            Lichtansteuerung HD AB 8:
                always
            Lichtfunktion C 8:
                0
            Lichtfunktion D 8:
                0
            Dimmwert CD 8:
                0
            Dimming Direction CD 8:
                maximize
            Lichtfunktion E 8:
                0
            Lichtfunktion F 8:
                0
            Dimmwert EF 8:
                0
            Dimming Direction EF 8:
                maximize
            Lichtfunktion G 8:
                0
            Lichtfunktion H 8:
                0
            Dimmwert GH 8:
                0
            Dimming Direction GH 8:
                maximize
            Lasttyp 9:
            BAP Bitposition 9:
                41
            Reserved 9:
                0
            Fehlerort mittleres Byte DTC-DFCC 9:
                1d
            Lichtfunktion A 9:
                14
            Lichtfunktion B 9:
                15
            Dimmwert AB 9:
                100
            Lichtansteuerung HD AB 9:
                always
            Lichtfunktion C 9:
                0
            Lichtfunktion D 9:
                0
            Dimmwert CD 9:
                0
            Dimming Direction CD 9:
                maximize
            Lichtfunktion E 9:
                0
            Lichtfunktion F 9:
                0
            Dimmwert EF 9:
                0
            Dimming Direction EF 9:
                maximize
            Lichtfunktion G 9:
                0
            Lichtfunktion H 9:
                0
            Dimmwert GH 9:
                0
            Dimming Direction GH 9:
                maximize
            Lasttyp 10:
                not active
            BAP Bitposition 10:
                0
            Reserved 10:
                0
            Fehlerort mittleres Byte DTC-DFCC 10:
                0
            Lichtfunktion A 10:
                0
            Lichtfunktion B 10:
                0
            Dimmwert AB 10:
                0
            Lichtansteuerung HD AB 10:
                always
            Lichtfunktion C 10:
                0
            Lichtfunktion D 10:
                0
            Dimmwert CD 10:
                0
            Dimming Direction CD 10:
                maximize
            Lichtfunktion E 10:
                0
            Lichtfunktion F 10:
                0
            Dimmwert EF 10:
                0
            Dimming Direction EF 10:
                maximize
            Lichtfunktion G 10:
                0
            Lichtfunktion H 10:
                0
            Dimmwert GH 10:
                0
            Dimming Direction GH 10:
                maximize
            Lasttyp 11:
                not active
            BAP Bitposition 11:
                0
            Reserved 11:
                0
            Fehlerort mittleres Byte DTC-DFCC 11:
                0
            Lichtfunktion A 11:
                0
            Lichtfunktion B 11:
                0
            Dimmwert AB 11:
                0
            Lichtansteuerung HD AB 11:
                always
            Lichtfunktion C 11:
                0
            Lichtfunktion D 11:
                0
            Dimmwert CD 11:
                0
            Dimming Direction CD 11:
                maximize
            Lichtfunktion E 11:
                0
            Lichtfunktion F 11:
                0
            Dimmwert EF 11:
                0
            Dimming Direction EF 11:
                maximize
            Lichtfunktion G 11:
                0
            Lichtfunktion H 11:
                0
            Dimmwert GH 11:
                0
            Dimming Direction GH 11:
                maximize
            Lasttyp 12:
            BAP Bitposition 12:
                38
            Reserved 12:
                0
            Fehlerort mittleres Byte DTC-DFCC 12:
                22
            Lichtfunktion A 12:
                18
            Lichtfunktion B 12:
                22
            Dimmwert AB 12:
                100
            Lichtansteuerung HD AB 12:
                always
            Lichtfunktion C 12:
                0
            Lichtfunktion D 12:
                0
            Dimmwert CD 12:
                0
            Dimming Direction CD 12:
                maximize
            Lichtfunktion E 12:
                0
            Lichtfunktion F 12:
                0
            Dimmwert EF 12:
                0
            Dimming Direction EF 12:
                maximize
            Lichtfunktion G 12:
                0
            Lichtfunktion H 12:
                0
            Dimmwert GH 12:
                0
            Dimming Direction GH 12:
                maximize
            Lasttyp 13:
            BAP Bitposition 13:
                42
            Reserved 13:
                0
            Fehlerort mittleres Byte DTC-DFCC 13:
                23
            Lichtfunktion A 13:
                19
            Lichtfunktion B 13:
                23
            Dimmwert AB 13:
                100
            Lichtansteuerung HD AB 13:
                always
            Lichtfunktion  C 13:
                0
            Lichtfunktion D 13:
                0
            Dimmwert CD 13:
                0
            Dimming Direction CD 13:
                maximize
            Lichtfunktion E 13:
                0
            Lichtfunktion F 13:
                0
            Dimmwert EF 13:
                0
            Dimming Direction EF 13:
                maximize
            Lichtfunktion G 13:
                0
            Lichtfunktion H 13:
                0
            Dimmwert GH 13:
                0
            Dimming Direction GH 13:
                maximize
            Lasttyp 14:
                not active
            BAP Bitposition 14:
                0
            Reserved 14:
                0
            Fehlerort mittleres Byte DTC-DFCC 14:
                0
            Lichtfunktion A 14:
                0
            Lichtfunktion B 14:
                0
            Dimmwert AB 14:
                0
            Lichtansteuerung HD AB 14:
                always
            Lichtfunktion C 14:
                0
            Lichtfunktion D 14:
                0
            Dimmwert CD 14:
                0
            Dimming Direction CD 14:
                maximize
            Lichtfunktion E 14:
                0
            Lichtfunktion F 14:
                0
            Dimmwert EF 14:
                0
            Dimming Direction EF 14:
                maximize
            Lichtfunktion G 14:
                0
            Lichtfunktion H 14:
                0
            Dimmwert GH 14:
                0
            Dimming Direction GH 14:
                maximize
            Lasttyp 15:
                not active
            BAP Bitposition 15:
                0
            Reserved 15:
                0
            Fehlerort mittleres Byte DTC-DFCC 15:
                0
            Lichtfunktion A 15:
                0
            Lichtfunktion B 15:
                0
            Dimmwert AB 15:
                0
            Lichtansteuerung HD AB 15:
                always
            Lichtfunktion C 15:
                0
            Lichtfunktion D 15:
                0
            Dimmwert CD 15:
                0
            Dimming Direction CD 15:
                maximize
            Lichtfunktion E 15:
                0
            Lichtfunktion F 15:
                0
            Dimmwert EF 15:
                0
            Dimming Direction EF 15:
                maximize
            Lichtfunktion G 15:
                0
            Lichtfunktion H 15:
                0
            Dimmwert GH 15:
                0
            Dimming Direction GH 15:
                maximize
            Lasttyp 16:
                not active
            BAP Bitposition 16:
                35
            Reserved 16:
                0
            Fehlerort mittleres Byte DTC-DFCC 16:
                17
            Lichtfunktion A 16:
                0
            Lichtfunktion B 16:
                0
            Dimmwert AB 16:
                0
            Lichtansteuerung HD AB 16:
                always
            Lichtfunktion C 16:
                20
            Lichtfunktion D 16:
                0
            Dimmwert CD 16:
                100
            Dimming Direction CD 16:
                maximize
            Lichtfunktion E 16:
                0
            Lichtfunktion F 16:
                0
            Dimmwert EF 16:
                0
            Dimming Direction EF 16:
                maximize
            Lichtfunktion G 16:
                0
            Lichtfunktion H 16:
                0
            Dimmwert GH 16:
                0
            Dimming Direction GH 16:
                maximize
            Lasttyp 17:
                not active
            BAP Bitposition 17:
                3f
            Reserved 17:
                0
            Fehlerort mittleres Byte DTC-DFCC 17:
                19
            Lichtfunktion A 17:
                0
            Lichtfunktion  B 17:
                0
            Dimmwert AB 17:
                0
            Lichtansteuerung HD AB 17:
                always
            Lichtfunktion C 17:
                20
            Lichtfunktion D 17:
                0
            Dimmwert CD 17:
                100
            Dimming Direction CD 17:
                maximize
            Lichtfunktion E 17:
                0
            Lichtfunktion F 17:
                0
            Dimmwert EF 17:
                0
            Dimming Direction EF 17:
                maximize
            Lichtfunktion G 17:
                0
            Lichtfunktion H 17:
                0
            Dimmwert GH 17:
                0
            Dimming Direction GH 17:
                maximize
            Lasttyp 18:
                12 - Blinkleuchten
            BAP Bitposition 18:
                8
            Reserved 18:
                0
            Fehlerort mittleres Byte DTC-DFCC 18:
                16
            Lichtfunktion A 18:
                2
            Lichtfunktion B 18:
                0
            Dimmwert AB 18:
                100
            Lichtansteuerung HD AB 18:
                always
            Lichtfunktion C 18:
                33
            Lichtfunktion D 18:
                0
            Dimmwert CD 18:
                100
            Dimming Direction CD 18:
                maximize
            Lichtfunktion E 18:
                0
            Lichtfunktion F 18:
                0
            Dimmwert EF 18:
                0
            Dimming Direction EF 18:
                maximize
            Lichtfunktion G 18:
                0
            Lichtfunktion H 18:
                0
            Dimmwert GH 18:
                0
            Dimming Direction GH 18:
                maximize
            Lasttyp 19:
                12 - Blinkleuchten
            BAP Bitposition 19:
                18
            Reserved 19:
                0
            Fehlerort mittleres Byte DTC-DFCC 19:
                18
            Lichtfunktion A 19:
                4
            Lichtfunktion B 19:
                0
            Dimmwert AB 19:
                100
            Lichtansteuerung HD AB 19:
                always
            Lichtfunktion C 19:
                33
            Lichtfunktion D 19:
                0
            Dimmwert CD 19:
                100
            Dimming Direction CD 19:
                maximize
            Lichtfunktion E 19:
                0
            Lichtfunktion F 19:
                0
            Dimmwert EF 19:
                0
            Dimming Direction EF 19:
                maximize
            Lichtfunktion G 19:
                0
            Lichtfunktion H 19:
                0
            Dimmwert GH 19:
                0
            Dimming Direction GH 19:
                maximize
            Lasttyp 20:
                34 - LED Bremsleuchten
            BAP Bitposition 20:
                9
            Reserved 20:
                0
            Fehlerort mittleres Byte DTC-DFCC 20:
                39
            Lichtfunktion A 20:
                24
            Lichtfunktion B 20:
                0
            Dimmwert AB 20:
                100
            Lichtansteuerung HD AB 20:
                always
            Lichtfunktion C 20:
                0
            Lichtfunktion D 20:
                0
            Dimmwert CD 20:
                0
            Dimming Direction CD 20:
                maximize
            Lichtfunktion E 20:
                30
            Lichtfunktion F 20:
                0
            Dimmwert EF 20:
                0
            Dimming Direction EF 20:
                maximize
            Lichtfunktion G 20:
                0
            Lichtfunktion H 20:
                0
            Dimmwert GH 20:
                0
            Dimming Direction GH 20:
                maximize
            Lasttyp 21:
            BAP Bitposition 21:
                19
            Reserved 21:
                0
            Fehlerort mittleres Byte DTC-DFCC 21:
                3a
            Lichtfunktion A 21:
                24
            Lichtfunktion B 21:
                0
            Dimmwert AB 21:
                100
            Lichtansteuerung HD AB 21:
                always
            Lichtfunktion C 21:
                0
            Lichtfunktion D 21:
                0
            Dimmwert CD 21:
                0
            Dimming Direction CD 21:
                maximize
            Lichtfunktion E 21:
                30
            Lichtfunktion F 21:
                0
            Dimmwert EF 21:
                0
            Dimming Direction EF 21:
                maximize
            Lichtfunktion G 21:
                0
            Lichtfunktion H 21:
                0
            Dimmwert GH 21:
                0
            Dimming Direction GH 21:
                maximize
            Lasttyp 22:
            BAP Bitposition 22:
                29
            Reserved 22:
                0
            Fehlerort mittleres Byte DTC-DFCC 22:
                2c
            Lichtfunktion A 22:
                24
            Lichtfunktion B 22:
                0
            Dimmwert AB 22:
                100
            Lichtansteuerung HD AB 22:
                always
            Lichtfunktion C 22:
                0
            Lichtfunktion D 22:
                0
            Dimmwert CD 22:
                0
            Dimming Direction CD 22:
                maximize
            Lichtfunktion E 22:
                0
            Lichtfunktion F 22:
                0
            Dimmwert EF 22:
                0
            Dimming Direction EF 22:
                maximize
            Lichtfunktion G 22:
                0
            Lichtfunktion H 22:
                0
            Dimmwert GH 22:
                0
            Dimming Direction GH 22:
                maximize
            Lasttyp 23:
                32 - allgemeine LED bis 12W
            BAP Bitposition 23:
                a
            Reserved 23:
                0
            Fehlerort mittleres Byte DTC-DFCC 23:
                29
            Lichtfunktion A 23:
                8
            Lichtfunktion B 23:
                9
            Dimmwert AB 23:
                100
            Lichtansteuerung HD AB 23:
                always
            Lichtfunktion C 23:
                30
            Lichtfunktion D 23:
                0
            Dimmwert CD 23:
                100
            Dimming Direction CD 23:
                maximize
            Lichtfunktion E 23:
                0
            Lichtfunktion F 23:
                0
            Dimmwert EF 23:
                0
            Dimming Direction EF 23:
                maximize
            Lichtfunktion G 23:
                0
            Lichtfunktion H 23:
                0
            Dimmwert GH 23:
                0
            Dimming Direction GH 23:
                maximize
            Lasttyp 24:
            BAP Bitposition 24:
                1a
            Reserved 24:
                0
            Fehlerort mittleres Byte DTC-DFCC 24:
                2a
            Lichtfunktion A 24:
                8
            Lichtfunktion B 24:
                10
            Dimmwert AB 24:
                100
            Lichtansteuerung HD AB 24:
                always
            Lichtfunktion C 24:
                30
            Lichtfunktion D 24:
                0
            Dimmwert CD 24:
                100
            Dimming Direction CD 24:
                maximize
            Lichtfunktion E 24:
                0
            Lichtfunktion F 24:
                0
            Dimmwert EF 24:
                0
            Dimming Direction EF 24:
                maximize
            Lichtfunktion G 24:
                0
            Lichtfunktion H 24:
                0
            Dimmwert GH 24:
                0
            Dimming Direction GH 24:
                maximize
            Lasttyp 25:
                43 - allgemeine LED
            BAP Bitposition 25:
                28
            Reserved 25:
                0
            Fehlerort mittleres Byte DTC-DFCC 25:
                30
            Lichtfunktion A 25:
                8
            Lichtfunktion B 25:
                30
            Dimmwert AB 25:
                127
            Lichtansteuerung HD AB 25:
                always
            Lichtfunktion C 25:
                0
            Lichtfunktion D 25:
                0
            Dimmwert CD 25:
                0
            Dimming Direction CD 25:
                maximize
            Lichtfunktion E 25:
                0
            Lichtfunktion F 25:
                0
            Dimmwert EF 25:
                0
            Dimming Direction EF 25:
                maximize
            Lichtfunktion G 25:
                0
            Lichtfunktion H 25:
                0
            Dimmwert GH 25:
                0
            Dimming Direction GH 25:
                maximize
            Lasttyp 26:
            BAP Bitposition 26:
                c
            Reserved 26:
                0
            Fehlerort mittleres Byte DTC-DFCC 26:
                2e
            Lichtfunktion A 26:
                26
            Lichtfunktion B 26:
                0
            Dimmwert AB 26:
                100
            Lichtansteuerung HD AB 26:
                always
            Lichtfunktion C 26:
                0
            Lichtfunktion D 26:
                0
            Dimmwert CD 26:
                0
            Dimming Direction CD 26:
                maximize
            Lichtfunktion E 26:
                0
            Lichtfunktion F 26:
                0
            Dimmwert EF 26:
                0
            Dimming Direction EF 26:
                maximize
            Lichtfunktion G 26:
                0
            Lichtfunktion H 26:
                0
            Dimmwert GH 26:
                0
            Dimming Direction GH 26:
                maximize
            Lasttyp 27:
            BAP Bitposition 27:
                1c
            Reserved 27:
                0
            Fehlerort mittleres Byte DTC-DFCC 27:
                2f
            Lichtfunktion A 27:
                0
            Lichtfunktion B 27:
                0
            Dimmwert AB 27:
                0
            Lichtansteuerung HD AB 27:
                always
            Lichtfunktion C 27:
                0
            Lichtfunktion D 27:
                0
            Dimmwert CD 27:
                0
            Dimming Direction CD 27:
                maximize
            Lichtfunktion E 27:
                0
            Lichtfunktion F 27:
                0
            Dimmwert EF 27:
                0
            Dimming Direction EF 27:
                maximize
            Lichtfunktion G 27:
                0
            Lichtfunktion H 27:
                0
            Dimmwert GH 27:
                0
            Dimming Direction GH 27:
                maximize
            Lasttyp 28:
            BAP Bitposition 28:
                b
            Reserved 28:
                0
            Fehlerort mittleres Byte DTC-DFCC 28:
                31
            Lichtfunktion A 28:
                25
            Lichtfunktion B 28:
                0
            Dimmwert AB 28:
                100
            Lichtansteuerung HD AB 28:
                always
            Lichtfunktion C 28:
                0
            Lichtfunktion D 28:
                0
            Dimmwert CD 28:
                0
            Dimming Direction CD 28:
                maximize
            Lichtfunktion E 28:
                0
            Lichtfunktion F 28:
                0
            Dimmwert EF 28:
                0
            Dimming Direction EF 28:
                maximize
            Lichtfunktion G 28:
                0
            Lichtfunktion H 28:
                0
            Dimmwert GH 28:
                0
            Dimming Direction GH 28:
                maximize
            Lasttyp 29:
            BAP Bitposition 29:
                1b
            Reserved 29:
                0
            Fehlerort mittleres Byte DTC-DFCC 29:
                32
            Lichtfunktion A 29:
                25
            Lichtfunktion B 29:
                0
            Dimmwert AB 29:
                100
            Lichtfunktion C 29:
                0
            Lichtansteuerung HD AB 29:
                always
            Lichtfunktion D 29:
                0
            Dimmwert CD 29:
                0
            Dimming Direction CD 29:
                maximize
            Lichtfunktion E 29:
                0
            Lichtfunktion F 29:
                0
            Dimmwert EF 29:
                0
            Dimming Direction EF 29:
                maximize
            Lichtfunktion G 29:
                0
            Lichtfunktion H 29:
                0
            Dimmwert GH 29:
                0
            Dimming Direction GH 29:
                maximize
            Lasttyp 30:
                not active
            BAP Bitposition 30:
                0
            Reserved 30:
                0
            Fehlerort mittleres Byte DTC-DFCC 30:
                0
            Lichtfunktion A 30:
                0
            Lichtfunktion B 30:
                0
            Dimmwert AB 30:
                0
            Lichtansteuerung HD AB 30:
                always
            Lichtfunktion C 30:
                0
            Lichtfunktion D 30:
                0
            Dimmwert CD 30:
                0
            Dimming Direction CD 30:
                maximize
            Lichtfunktion E 30:
                0
            Lichtfunktion F 30:
                0
            Dimmwert EF 30:
                0
            Dimming Direction EF 30:
                maximize
            Lichtfunktion G 30:
                0
            Lichtfunktion H 30:
                0
            Dimmwert GH 30:
                0
            Dimming Direction GH 30:
                maximize
            Lasttyp 31:
                not active
            BAP Bitposition 31:
                0
            Reserved 31:
                0
            Fehlerort mittleres Byte DTC-DFCC 31:
                3
            Lichtfunktion A 31:
                45
            Lichtfunktion B 31:
                0
            Dimmwert AB 31:
                100
            Lichtansteuerung HD AB 31:
                always
            Lichtfunktion C 31:
                0
            Lichtfunktion D 31:
                0
            Dimmwert CD 31:
                0
            Dimming Direction CD 31:
                maximize
            Lichtfunktion E 31:
                0
            Lichtfunktion F 31:
                0
            Dimmwert EF 31:
                0
            Dimming Direction EF 31:
                maximize
            Lichtfunktion G 31:
                0
            Lichtfunktion H 31:
                0
            Dimmwert GH 31:
                0
            Dimming Direction GH 31:
                maximize
            Lasttyp 32:
                not active
            BAP Bitposition 32:
                0
            Reserved 32:
                0
            Fehlerort mittleres Byte DTC-DFCC 32:
                4
            Lichtfunktion A 32:
                46
            Lichtfunktion B 32:
                0
            Dimmwert AB 32:
                100
            Lichtansteuerung HD AB 32:
                always
            Lichtfunktion C 32:
                0
            Lichtfunktion D 32:
                0
            Dimmwert CD 32:
                0
            Dimming Direction CD 32:
                maximize
            Lichtfunktion E 32:
                0
            Lichtfunktion F 32:
                0
            Dimmwert EF 32:
                0
            Dimming Direction EF 32:
                maximize
            Lichtfunktion G 32:
                0
            Lichtfunktion H 32:
                0
            Dimmwert GH 32:
                0
            Dimming Direction GH 32:
                maximize
            Lasttyp 33:
                not active
            BAP Bitposition 33:
                0
            Reserved 33:
                0
            Fehlerort mittleres Byte DTC-DFCC 33:
                5
            Lichtfunktion A 33:
                47
            Lichtfunktion B 33:
                0
            Dimmwert AB 33:
                100
            Lichtansteuerung HD AB 33:
                always
            Lichtfunktion C 33:
                0
            Lichtfunktion D 33:
                0
            Dimmwert CD 33:
                0
            Dimming Direction CD 33:
                maximize
            Lichtfunktion E 33:
                0
            Lichtfunktion F 33:
                0
            Dimmwert EF 33:
                0
            Dimming Direction EF 33:
                maximize
            Lichtfunktion G 33:
                0
            Lichtfunktion H 33:
                0
            Dimmwert GH 33:
                0
            Dimming Direction GH 33:
                maximize
            Lasttyp 34:
                not active
            BAP Bitposition 34:
                0
            Reserved 34:
                0
            Fehlerort mittleres Byte DTC-DFCC 34:
                6
            Lichtfunktion A 34:
                48
            Lichtfunktion B 34:
                0
            Dimmwert AB 34:
                100
            Lichtansteuerung HD AB 34:
                always
            Lichtfunktion C 34:
                0
            Lichtfunktion D 34:
                0
            Dimmwert CD 34:
                0
            Dimming Direction CD 34:
                maximize
            Lichtfunktion E 34:
                0
            Lichtfunktion F 34:
                0
            Dimmwert EF 34:
                0
            Dimming Direction EF 34:
                maximize
            Lichtfunktion G 34:
                0
            Lichtfunktion H 34:
                0
            Dimmwert GH 34:
                0
            Dimming Direction GH 34:
                maximize
        Comfort illumination:
            Coming Home Verbaustatus:
                automatic
            Menuesteuerung Coming Home Werkseinstellung:
                active
            Menueeinstellung Cominghome:
                10 seconds
            Coming home Leuchten:
                Low beam
            Coming-home Einschaltereignis:
                driver door
            Helligkeitsschwelle Infrarot-Messung:
                12 lx
            Leaving-Home Verbausstatus:
                Enabled
            Menuesteuerung Leaving-home Freischaltung per BAP:
                active
            Menueeinstellung Leaving-home Zeit per BAP:
                10 seconds
            Helligkeitsschwelle Forward-Messung:
                46400 lx
        Seat heater level current consumption allocation:
            Sitzheizung Stufe 1 untere Schaltschwelle:
                32.00 °C
            Sitzheizung Stufe 1 obere Schaltschwelle:
                33.00 °C
            Sitzheizung Stufe 2 untere Schaltschwelle:
                32.00 °C
            Sitzheizung Stufe 2 obere Schaltschwelle:
                33.00 °C
            Sitzheizung Stufe 3 untere Schaltschwelle:
                36.50 °C
            Sitzheizung Stufe 3 obere Schaltschwelle:
                37.50 °C
            Sitzheizung Stufe 4 untere Schaltschwelle:
                36.50 °C
            Sitzheizung Stufe 4 obere Schaltschwelle:
                37.50 °C
            Sitzheizung Stufe 5 untere Schaltschwelle:
                40.00 °C
            Sitzheizung Stufe 5 obere Schaltschwelle:
                41.00 °C
            Sitzheizung Stufe 6 untere Schaltschwelle:
                40.00 °C
            Sitzheizung Stufe 6 obere Schaltschwelle:
                41.00 °C
            Sitzheizung Filterkonstante fuer Waermefluss:
                30 s
            Sitzheizung Regeltemperaturkorrektur bei Waermefluss:
                1.10 °C
        Innenbeleuchtung KL 58xs max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.00
            y1:
                100.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xt min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                6.00
            y1:
                6.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xt max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.00
            y1:
                100.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xd log Bus:
            x0:
                0.00 %
            x1:
                6.00 %
            x2:
                16.00 %
            x3:
                30.00 %
            x4:
                60.00 %
            x5:
                100.00 %
            y0:
                10
            y1:
                10
            y2:
                100
            y3:
                150
            y4:
                220
            y5:
                253
        Innenbeleuchtung KL 58xd max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                200 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                16.00
            y1:
                16.00
            y2:
                100.00
            y3:
                100.00
            y4:
                100.00
        Innenbeleuchtung KL 58xs PWM:
            x0:
                0.00 %
            x1:
                50.00 %
            x2:
                100.00 %
            y0:
                0.00 %
            y1:
                50.00 %
            y2:
                100.00 %
        Innenbeleuchtung KL 58xd PWM:
            x0:
                0
            x1:
                10
            x2:
                50
            x3:
                100
            x4:
                220
            x5:
                253
            y0:
                2.00 %
            y1:
                2.00 %
            y2:
                6.00 %
            y3:
                10.00 %
            y4:
                80.00 %
            y5:
                100.00 %
        Innenbeleuchtung KL 58xt PWM:
            x0:
                0.00 %
            x1:
                50.00 %
            x2:
                100.00 %
            y0:
                0.00 %
            y1:
                50.00 %
            y2:
                100.00 %
        Rear Window Wiper:
            Komfortwischen Heck:
                active
            Menuesteuerung Komfortwischen HW:
                active
            Automatisches Heckwischen:
                active
            Traenenwischen Heck:
                not active
            Heckwischer Weiterlauf:
                not active
            Kein automatisches Abparken:
                not active
            Komofortwischen Heck Intervallpausenzeit Stufe Intervall:
                7 s
            Komofortwischen Heck Intervallpausenzeit Stufe Automatik:
                7 s
            Komofortwischen Heck Intervallpausenzeit Stufe 1:
                5 s
            Komofortwischen Heck Intervallpausenzeit Stufe 2:
                3 s
        upper turn position:
                166.51 °
        lower turn position:
                25.51 °
        Position during interval mode:
                25.51 °
        Alternating park position 1:
                8.51 °
        Alternating park position 2:
                22.51 °
        Service position:
                166.51 °
        Innenbeleuchtung Tasterdimmung:
            tasterdimmung x0:
                0 ms
            tasterdimmung x1:
                2000 ms
            tasterdimmung x2:
                3000 ms
            tasterdimmung x3:
                4000 ms
            tasterdimmung x4:
                5100 ms
            tasterdimmung y0:
                1.00 %
            tasterdimmung y1:
                5.00
            tasterdimmung y2:
                15.00
            tasterdimmung y3:
                40.00
            tasterdimmung y4:
                100.00
        Innenbeleuchtung Hochdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                0.00 %
            y1:
                1.00 %
            y2:
                3.00 %
            y3:
                5.00 %
            y4:
                11.00 %
            y5:
                22.00 %
            y6:
                40.00 %
            y7:
                80.00 %
            y8:
                95.00 %
            y9:
                100.00 %
            y10:
                100.00 %
        Innenbeleuchtung Fotosensor:
            x0:
                0
            x1:
                50
            x2:
                100
            x3:
                200
            x4:
                253
            x5:
                0
            x6:
                0
            x7:
                0
            x8:
                0
            x9:
                0
            x10:
                0
            y0:
                0 lx
            y1:
                50 lx
            y2:
                100 lx
            y3:
                200
            y4:
                500
            y5:
                0
            y6:
                0 lx
            y7:
                0 lx
            y8:
                0 lx
            y9:
                0 lx
            y10:
                0 lx
        Innenbeleuchtung KL 58xs min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                510 lx
            y0:
                6.00
            y1:
                6.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xd min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                220 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                6.00
            y1:
                6.00
            y2:
                100.00
            y3:
                100.00
            y4:
                100.00
        Innenbeleuchtung Abdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                100.00 %
            y1:
                100.00 %
            y2:
                95.00 %
            y3:
                80.00 %
            y4:
                40.00 %
            y5:
                20.00 %
            y6:
                10.00 %
            y7:
                5.00 %
            y8:
                3.00 %
            y9:
                1.00 %
            y10:
                0.00 %
        Static AFS light:
                double sided
            Vorschrift:
                ECE R119
            Untere Geschwindigkeitsschwelle:
                0.00 km/h
            Obere Geschwindigkeitsschwelle:
                40.00 km/h
            Steering wheel angle, offset:
                0.25 °
            Unterer Lenkradwinkel:
                30 °
            Oberer Lenkradwinkel:
                90 °
            Abdimmgeschwindigkeit:
                50.00 %/s
            Maximaltemperatur:
                100.00 °C
            obere Grenztemperatur:
                95.00 °C
            untere Grenztemperatur:
                80.00 °C
        Assistance light functions:
            Notbremsanzeige NBA:
                active
            Menuesteuerung Fernlichtassistent:
                Not present
            Fernlichtassistent Zeitverzoegerungswert:
                0 ms
            Umfeldleuchte als Manoevrierleuchte:
                not active
            Fernlichtassistent Reset:
                active
            Menuesteuerung Fernlichtassistent Werkseinstellung:
                Not present
            Assistenzfahrlicht bei Regen:
                active
            Fahrlichtwarnung_Hinweis_Konfig:
                kein_Hinweis
            LS_Error_Ausgabe:
                not active
            AFL Zeitverzoegerung:
                2000 ms
            Lichtsensorempfindlichkeit:
                normal
            Fahrlicht_Hinweis_mehrfach:
                not active
        Ambient lighting:
            Defaultwert Ambienteprofil Fussraum:
                20 %
            Defaultwert Ambienteprofil Tuer:
                40 %
            Defaultwert Ambienteprofil Vorn:
                40 %
            Tuerinnengriffbeleuchtung mit I-Tafel:
                not installed
            Tuerinnengriff mit Tuertafel:
                not installed
            Innenlichtinszenierung:
                not enabled
        Roller test bench mode, functional:
                not active
        LuB Lichtrouter Kennlinie 1:
            x0:
                0.00 %
            x1:
                5.00 %
            x2:
                50.00 %
            x3:
                75.00 %
            x4:
                110.00
            x5:
                126.50
            y0:
                0.00 %
            y1:
                6.00 %
            y2:
                16.00 %
            y3:
                30.00 %
            y4:
                60.00 %
            y5:
                100.00 %
        Characteristics in production mode:
            Headlamp washer system:
                2000 ms
        Kopfraumheizung:
            blower_speed:
                1
            temperature:
                -2
        Convert. top oper.:
            Komfortbedienung Verdeck global:
                active
            Komfortbedienung Verdeck oeffnen:
                active
            Komfortbedienung Verdeck schliessen:
                active
            Verdeck oeffnen via Schliesszylinder:
                active
            Verdeck schliessen via Schliesszylinder:
                active
            Verdeck oeffnen via Funkfernbedienung:
                active
            Verdeck schliessen via Funkfernbedienung:
                active
            Verdeck oeffnen via Kessy:
                active
            Verdeck schliessen via Kessy:
                active
            Doppelpuls nur Verdeck:
                active
            Verdeck mit Schiebedach:
                not active
            Heckdeckel sperren bei Verdeckbetrieb:
                not active
            Heckschloss oeffnen durch Verdeck-SG:
                not active
            Reichweitenbegrenzung fuer Servoheck schliessen:
                not active
            ZV verriegeln bei Klemme 15 Ein:
                not active
        After-run for park light:
            Bedingungen zur Beendigung des Standlichtnachlaufs:
                abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
            Standlicht-Nachlaufzeit:
                30 min
        Dyn. turn signal modes:
            Schluessel_Anlern_Blinken:
                not active
            UGDO_ Anlern_Blinken:
                not active
            ZV_Blinken_zu:
                not active
            ZV_Blinken_auf:
                not active
            Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken:
                not active
            DWA_Schaerfungsquittung:
                not active
            DWA_Alarm_Blinken:
                not active
            Taxialarmblinken:
                not active
            Panikblinken:
                not active
            Multi_kollisions_Blinken:
                not active
            Notwarn_blinken_NBA_Phase_2:
                active
            Richtungs_blinken_rechts:
                not active
            Richtungs_blinken_links:
                not active
            ABBA_Blinken:
                not active
            Crashblinken:
                active
            Warnblinken_Zuendung_EIN:
                not active
            Warnblinken_Zuendung_AUS:
                not active
            Emergency_alert_blinken:
                not active
        Interior lighting:
            Innenlicht bei offenem Heckdeckel einschalten:
                active
            KL30G ohne PWM:
                not active
            KL58 Einschalten mit Rampe:
                active
            KL58 Verriegelungsausschalten:
                not active
            Lichtsensor wirkt auf Suchbeleuchtung:
                active
            Suchbeleuchtung Festwert:
                60 %
        Int. light, 2nd generation:
            Aufloesung Dimmzeit:
                0.25 s
            weicher Farbwechsel:
                not active
            Tuertafelbeleuchtung mehrfarbig:
                active
            Instrumententafelbeleuchtung mehrfarbig:
                not active
            Cockpitbeleuchtung mehrfarbig:
                not active
            Lautsprecherbeleuchtung mehrfarbig:
                not active
            Mittelkonsolenbeleuchtung mehrfarbig:
                not active
            Dachbeleuchtung mehrfarbig:
                not active
            Panoramaschiebedachbeleuchtung mehrfarbig:
                not active
            Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren:
                not active
            BAP Farbwert Farbe 1:
                2
            BAP Farbwert Farbe 2:
                3
            BAP Farbwert Farbe 3:
                1
            Defaultwert Ambienteprofil Mittelkonsole:
                80 %
            Defaultwert Ambienteprofil Dach:
                80 %
            Defaultwert Ambienteprofil Farbe:
                2
            Helligkeit Tuertafelbeleuchtung nicht berechnen:
                not active
            Helligkeit Instrumententafelbeleuchtung nicht berechnen:
                not active
            Helligkeit Cockpitbeleuchtung nicht berechnen:
                not active
            Helligkeit Lautsprecherbeleuchtung nicht berechnen:
                not active
            Helligkeit Mittelkonsolenbeleuchtung nicht berechnen:
                active
            Helligkeit Dachbeleuchtung nicht berechnen:
                active
            Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen:
                active
            Farbausgabe Tuertafelbeleuchtung nicht berechnen:
                not active
            Farbausgabe Instrumententafelbeleuchtung nicht berechnen:
                active
            Farbausgabe Cockpitbeleuchtung nicht berechnen:
                active
            Farbausgabe Lautsprecherbeleuchtung nicht berechnen:
                active
            Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen:
                active
            Farbausgabe Dachbeleuchtung nicht berechnen:
                active
            Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen:
                active
            Rotwert Farbe 1:
                225
            Gruenwert Farbe 1:
                225
            Blauwert Farbe 1:
                225
            Rotwert Farbe 2:
                225
            Gruenwert Farbe 2:
                225
            Blauwert Farbe 2:
                225
            Rotwert Farbe 3:
                225
            Gruenwert Farbe 3:
                225
            Blauwert Farbe 3:
                225
        Interior light, light configuration:
            Ambiente_Applikationsleisten_in_Tuertafel:
                not installed
            Ambiente_Lautsprecher:
                not installed
            Ambiente_Applikationsleisten_in_Instrumententafel:
                not installed
            Cockpitbeleuchtung:
                not installed
            Mittelkonsolenbeleuchtung:
                not installed
            Dachbeleuchtung:
                not installed
            Panoramaschiebedachbeleuchtung:
                not installed
            Fussraumbeleuchtung:
                not installed
            Farbwahl ueber HMI:
                not installed
            Farbwahl ueber Fahrprofil:
                not installed
            LIN-Dachkonsole lokal aktivierbar:
                not active
            Ambientemenue mit globalem aus:
                not active
            Ambientemenue mit alle Zonen:
                not active
        Characteristic curve:
            x0:
                0 lx
            x1:
                2000 lx
            x2:
                4000 lx
            x3:
                6000 lx
            x4:
                8000 lx
            x5:
                10200 lx
            y1_0:
                0
            y1_1:
                40
            y1_2:
                90
            y1_3:
                140
            y1_4:
                190
            y1_5:
                245
            y2_0:
                0
            y2_1:
                60
            y2_2:
                110
            y2_3:
                160
            y2_4:
                210
            y2_5:
                255
        LED bar setting values:
            Maximale Dauer fuer konstante Anzeige:
                0 s
            Sperrzeit:
                0 s
            Filterzeit Umgebungshelligkeit:
                1000 ms
            Filterzeit Anpassung:
                3000 ms
            Maximale Helligkeitsdifferenz:
                25
            Schwellwert Plausibilisierung RLS:
                393210 lx
            Schwellwert Plausibilisierung SLS:
                393210 lx
            Schwellwert Plausibilisierung Kombi-Fototransistor:
                0
        Seat fan charac. curve:
            Level_1_Sitz:
                25 %
            Level_1_Lehne:
                30 %
            Level_2_Sitz:
                25 %
            Level_2_Lehne:
                30 %
            Level_3_Sitz:
                53 %
            Level_3_Lehne:
                58 %
            Level_4_Sitz:
                53 %
            Level_4_Lehne:
                58 %
            Level_5_Sitz:
                80 %
            Level_5_Lehne:
                85 %
            Level_6_Sitz:
                80 %
            Level_6_Lehne:
                85 %
        Window heater:
            Temperaturabhaengige Einschaltzeit HSH:
                not active
            Temperaturabhaengige Einschaltzeit FSH:
                not active
            FSH Automatik:
                active
            Heckscheibenheizung Zeitwert:
                600 s
            Running time of heated front window:
                600 s
            Abschalttemperatur fuer Heckscheibenheizung:
                35.00 °C
            Abschalttemperatur fuer Frontscheibenheizung:
                35.00 °C
        debug_light_function:
            Adresse:
                0
            Bitmask:
                0
            Offset:
                0
            Divisor:
                0
            Polaritaet:
                0
            Aktivierung:
                0
            WBT-Ausgabe:
                0
        LIN-Mirrormode:
            Stufe:
                0
            Bitmaske:
                63
        ambient_lighting_lin_slaves_groups:
            pa_verbauinfo_gruppe_1:
                not installed
            pa_lichtfunktion_gruppe_1:
                Door
            pa_korrekturfaktor_gruppe_1:
                1.00
            pa_verbauinfo_gruppe_2:
                not installed
            pa_lichtfunktion_gruppe_2:
                Door
            pa_korrekturfaktor_gruppe_2:
                1.00
            pa_verbauinfo_gruppe_3:
                not installed
            pa_lichtfunktion_gruppe_3:
                Door
            pa_korrekturfaktor_gruppe_3:
                1.00
            pa_verbauinfo_gruppe_4:
                not installed
            pa_lichtfunktion_gruppe_4:
                Door
            pa_korrekturfaktor_gruppe_4:
                1.00
            pa_verbauinfo_gruppe_5:
                not installed
            pa_lichtfunktion_gruppe_5:
                Door
            pa_korrekturfaktor_gruppe_5:
                1.00
            pa_verbauinfo_gruppe_6:
                not installed
            pa_lichtfunktion_gruppe_6:
                Door
            pa_korrekturfaktor_gruppe_6:
                1.00
            pa_verbauinfo_gruppe_7:
                not installed
            pa_lichtfunktion_gruppe_7:
                Door
            pa_korrekturfaktor_gruppe_7:
                1.00
            pa_verbauinfo_gruppe_8:
                not installed
            pa_lichtfunktion_gruppe_8:
                Door
            pa_korrekturfaktor_gruppe_8:
                1.00
            pa_verbauinfo_gruppe_9:
                not installed
            pa_lichtfunktion_gruppe_9:
                Door
            pa_korrekturfaktor_gruppe_9:
                1.00
            pa_verbauinfo_gruppe_10:
                not installed
            pa_lichtfunktion_gruppe_10:
                Door
            pa_korrekturfaktor_gruppe_10:
                1.00
            pa_verbauinfo_gruppe_11:
                not installed
            pa_lichtfunktion_gruppe_11:
                Door
            pa_korrekturfaktor_gruppe_11:
                1.00
            pa_verbauinfo_gruppe_12:
                not installed
            pa_lichtfunktion_gruppe_12:
                Door
            pa_korrekturfaktor_gruppe_12:
                1.00
            pa_verbauinfo_gruppe_13:
                not installed
            pa_lichtfunktion_gruppe_13:
                Door
            pa_korrekturfaktor_gruppe_13:
                1.00
            pa_verbauinfo_gruppe_14:
                not installed
            pa_lichtfunktion_gruppe_14:
                Door
            pa_korrekturfaktor_gruppe_14:
                1.00
            pa_verbauinfo_gruppe_15:
                not installed
            pa_lichtfunktion_gruppe_15:
                Door
            pa_korrekturfaktor_gruppe_15:
                1.00
        Personalisierung:
            Personalisierung_aktiv:
                not active
            Aktivierungsoption_im_HMI-Menue_sichtbar:
                not active
            Benutzerkontenverwaltung_in_HMI-Menue_sichtbar:
                not active
            Personalisierungsfunktionen_in_HMI-Menue_sichtbar:
                not active
        Daytime running lights:
            Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht:
                not active
            Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge:
                active
            Standlicht aktiviert zusaetzlich Tagfahrlicht:
                not active
            Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
                not active
            Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht:
                active
            Tagfahrlichtkontrollleuchte:
                not active
            Fahrlicht bei Tag:
            Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
                active
            Tagfahrlicht nur in Schalterstellung AUTO:
                not active
        Remote_Start_Adaption:
            Anzahl zulaessiger Remotestarts:
                1
            RemoteStart Betrieb Dauer:
                1 min
        Leuchte 0 BLK VL B36:
            Lasttyp 0:
                12 - Blinkleuchten
            Lampendefektbit Position 0:
                34
                14
            Lichtfunktion A 0:
                Blinken links Hellphase
            Lichtfunktion B 0:
                nicht aktiv
            Dimmwert AB 0:
                100
                always
            Lichtfunktion C 0:
                nicht aktiv
            Lichtfunktion D 0:
                nicht aktiv
            Dimmwert CD 0:
                0
                maximize
            Lichtfunktion E 0:
                nicht aktiv
            Lichtfunktion F 0:
                nicht aktiv
            Dimmwert EF 0:
                0
                maximize
            Lichtfunktion H 0:
                nicht aktiv
            Dimmwert GH 0:
                0
                maximize
            Lichtfunktion G 0:
                nicht aktiv
        Leuchte1BLK VRB20:
            Lasttyp 1:
                12 - Blinkleuchten
            Lampendefektbitposition 1:
                3e
                15
            Lichtfunktion A 1:
                Blinken rechts Hellphase
            Lichtfunktion B 1:
                nicht aktiv
            Dimmwert AB 1:
                100
                always
            Lichtfunktion C 1:
                nicht aktiv
            Lichtfunktion D 1:
                nicht aktiv
            Dimmwert CD 1:
                0
                maximize
            Lichtfunktion E 1:
                nicht aktiv
            Lichtfunktion F 1:
                nicht aktiv
            Dimmwert EF 1:
                0
                maximize
            Lichtfunktion G 1:
                nicht aktiv
            Lichtfunktion H 1:
                nicht aktiv
            Dimmwert GH 1:
                0
                maximize
        Leuchte2SL VLB10:
            Lasttyp 2:
                not active
            Lampendefektbitposition 2:
                0
                0
            Lichtfunktion A 2:
                nicht aktiv
            Lichtfunktion B 2:
                nicht aktiv
            Dimmwert AB 2:
                0
                always
            Lichtfunktion C 2:
                nicht aktiv
            Lichtfunktion D 2:
                nicht aktiv
            Dimmwert CD 2:
                0
                maximize
            Lichtfunktion E 2:
                nicht aktiv
            Lichtfunktion F 2:
                nicht aktiv
            Dimmwert EF 2:
                0
                maximize
            Lichtfunktion G 2:
                Blinken links aktiv (beide Phasen)
            Lichtfunktion H 2:
                nicht aktiv
            Dimmwert GH 2:
                100
                minimize
        Leuchte3SL VRB21:
            Lasttyp 3:
                not active
            Lampendefektbitposition 3:
                0
                0
            Lichtfunktion A 3:
                nicht aktiv
            Lichtfunktion B 3:
                nicht aktiv
            Dimmwert AB 3:
                0
                always
            Lichtfunktion C 3:
                nicht aktiv
            Lichtfunktion D 3:
                nicht aktiv
            Dimmwert CD 3:
                0
                maximize
            Lichtfunktion E 3:
                nicht aktiv
            Lichtfunktion F 3:
                nicht aktiv
            Dimmwert EF 3:
                0
                maximize
            Lichtfunktion G 3:
                Blinken rechts aktiv (beide Phasen)
            Lichtfunktion H 3:
                nicht aktiv
            Dimmwert GH 3:
                100
                minimize
        Leuchte4TFL LB4:
            Lasttyp 4:
            Lampendefektbitposition 4:
                3a
                43
            Lichtfunktion A 4:
                Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
            Lichtfunktion B 4:
                Parklicht links (beidseitiges Parklicht aktiviert li & re)
            Dimmwert AB 4:
                30
                always
            Lichtfunktion C 4:
                Coming Home oder Leaving Home aktiv
            Lichtfunktion D 4:
                nicht aktiv
            Dimmwert CD 4:
                30
                maximize
            Lichtfunktion E 4:
                Tagfahrlicht
            Lichtfunktion F 4:
                nicht aktiv
            Dimmwert EF 4:
                100
                maximize
            Lichtfunktion G 4:
                nicht aktiv
            Lichtfunktion H 4:
                nicht aktiv
            Dimmwert GH 4:
                0
                maximize
        Leuchte5 TFL RB32:
            Lasttyp 5:
            Lampendefektbitposition 5:
                44
                44
            Lichtfunktion A 5:
            Lichtfunktion B 5:
                Parklicht rechts
            Dimmwert AB 5:
                30
                always
            Lichtfunktion C 5:
            Lichtfunktion D 5:
                nicht aktiv
            Dimmwert CD 5:
                30
                maximize
            Lichtfunktion E 5:
                Tagfahrlicht
            Lichtfunktion F 5:
                nicht aktiv
            Dimmwert EF 5:
                100
                maximize
            Lichtfunktion G 5:
                nicht aktiv
            Lichtfunktion H 5:
                nicht aktiv
            Dimmwert GH 5:
                0
                maximize
        Leuchte6ABL LC5:
            Lasttyp 6:
                11 - Abblendlicht
            Lampendefektbitposition 6:
                36
                1a
            Lichtfunktion A 6:
                Abblendlicht links
            Lichtfunktion B 6:
            Dimmwert AB 6:
                100
                always
            Lichtfunktion C 6:
                nicht aktiv
            Lichtfunktion D 6:
                nicht aktiv
            Dimmwert CD 6:
                0
                maximize
            Lichtfunktion E 6:
                nicht aktiv
            Lichtfunktion F 6:
                nicht aktiv
            Dimmwert EF 6:
                0
                maximize
            Lichtfunktion G 6:
                nicht aktiv
            Lichtfunktion H 6:
                nicht aktiv
            Dimmwert GH 6:
                0
                maximize
        Leuchte7ABL RB1:
            Lasttyp 7:
                11 - Abblendlicht
            Lampendefektbitposition 7:
                40
                1b
            Lichtfunktion A 7:
                Abblendlicht rechts
            Lichtfunktion B 7:
            Dimmwert AB 7:
                100
                always
            Lichtfunktion C 7:
                nicht aktiv
            Lichtfunktion D 7:
                nicht aktiv
            Dimmwert CD 7:
                0
                maximize
            Lichtfunktion E 7:
                nicht aktiv
            Lichtfunktion F 7:
                nicht aktiv
            Dimmwert EF 7:
                0
                maximize
            Lichtfunktion G 7:
                nicht aktiv
            Lichtfunktion H 7:
                nicht aktiv
            Dimmwert GH 7:
                0
                maximize
        Leuchte8FL LB39:
            Lasttyp 8:
            Lampendefektbitposition 8:
                37
                1c
            Lichtfunktion A 8:
                Fernlicht links
            Lichtfunktion B 8:
                Lichthupe generell
            Dimmwert AB 8:
                100
                always
            Lichtfunktion C 8:
                nicht aktiv
            Lichtfunktion D 8:
                nicht aktiv
            Dimmwert CD 8:
                0
                maximize
            Lichtfunktion E 8:
                nicht aktiv
            Lichtfunktion F 8:
                nicht aktiv
            Dimmwert EF 8:
                0
                maximize
            Lichtfunktion G 8:
                nicht aktiv
            Lichtfunktion H 8:
                nicht aktiv
            Dimmwert GH 8:
                0
                maximize
        Leuchte9FL RB2:
            Lasttyp 9:
            Lampendefektbitposition 9:
                41
                1d
            Lichtfunktion A 9:
                Fernlicht rechts
            Lichtfunktion B 9:
                Lichthupe generell
            Dimmwert AB 9:
                100
                always
            Lichtfunktion C 9:
                nicht aktiv
            Lichtfunktion D 9:
                nicht aktiv
            Dimmwert CD 9:
                0
                maximize
            Lichtfunktion E 9:
                nicht aktiv
            Lichtfunktion F 9:
                nicht aktiv
            Dimmwert EF 9:
                0
                maximize
            Lichtfunktion G 9:
                nicht aktiv
            Lichtfunktion H 9:
                nicht aktiv
            Dimmwert GH 9:
                0
                maximize
        Leuchte10SHUTTER LB23:
            Lasttyp 10:
                not active
            Lampendefektbitposition 10:
                0
                0
            Lichtfunktion A 10:
                nicht aktiv
            Lichtfunktion B 10:
                nicht aktiv
            Dimmwert AB 10:
                0
                always
            Lichtfunktion C 10:
                nicht aktiv
            Lichtfunktion D 10:
                nicht aktiv
            Dimmwert CD 10:
                0
                maximize
            Lichtfunktion E 10:
                nicht aktiv
            Lichtfunktion F 10:
                nicht aktiv
            Dimmwert EF 10:
                0
                maximize
            Lichtfunktion G 10:
                nicht aktiv
            Lichtfunktion H 10:
                nicht aktiv
            Dimmwert GH 10:
                0
                maximize
        Leuchte11SHUTTER RB22:
            Lasttyp 11:
                not active
            Lampendefektbitposition 11:
                0
                0
            Lichtfunktion A 11:
                nicht aktiv
            Lichtfunktion B 11:
                nicht aktiv
            Dimmwert AB 11:
                0
                always
            Lichtfunktion C 11:
                nicht aktiv
            Lichtfunktion D 11:
                nicht aktiv
            Dimmwert CD 11:
                0
                maximize
            Lichtfunktion E 11:
                nicht aktiv
            Lichtfunktion F 11:
                nicht aktiv
            Dimmwert EF 11:
                0
                maximize
            Lichtfunktion G 11:
                nicht aktiv
            Lichtfunktion H 11:
                nicht aktiv
            Dimmwert GH 11:
                0
                maximize
        Leuchte12NL LB45:
            Lasttyp 12:
            Lampendefektbitposition 12:
                38
                22
            Lichtfunktion A 12:
                Nebellicht links
            Lichtfunktion B 12:
                Abbiegelicht links
            Dimmwert AB 12:
                100
                always
            Lichtfunktion C 12:
                nicht aktiv
            Lichtfunktion D 12:
                nicht aktiv
            Dimmwert CD 12:
                0
                maximize
            Lichtfunktion E 12:
                nicht aktiv
            Lichtfunktion F 12:
                nicht aktiv
            Dimmwert EF 12:
                0
                maximize
            Lichtfunktion G 12:
                nicht aktiv
            Lichtfunktion H 12:
                nicht aktiv
            Dimmwert GH 12:
                0
                maximize
        Leuchte13NL RB5:
            Lasttyp 13:
            Lampendefektbitposition 13:
                42
                23
            Lichtfunktion A 13:
                Nebellicht rechts
            Lichtfunktion B 13:
                Abbiegelicht rechts
            Dimmwert AB 13:
                100
                always
            Lichtfunktion C 13:
                nicht aktiv
            Lichtfunktion D 13:
                nicht aktiv
            Dimmwert CD 13:
                0
                maximize
            Lichtfunktion E 13:
                nicht aktiv
            Lichtfunktion F 13:
                nicht aktiv
            Dimmwert EF 13:
                0
                maximize
            Lichtfunktion G 13:
                nicht aktiv
            Lichtfunktion H 13:
                nicht aktiv
            Dimmwert GH 13:
                0
                maximize
        Leuchten14AL LB6:
            Lasttyp 14:
                not active
            Lampendefektbitposition 14:
                0
                0
            Lichtfunktion A 14:
                nicht aktiv
            Lichtfunktion B 14:
                nicht aktiv
            Dimmwert AB 14:
                0
                always
            Lichtfunktion C 14:
                nicht aktiv
            Lichtfunktion D 14:
                nicht aktiv
            Dimmwert CD 14:
                0
                maximize
            Lichtfunktion E 14:
                nicht aktiv
            Lichtfunktion F 14:
                nicht aktiv
            Dimmwert EF 14:
                0
                maximize
            Lichtfunktion G 14:
                nicht aktiv
            Lichtfunktion H 14:
                nicht aktiv
            Dimmwert GH 14:
                0
                maximize
        Leuchte15AL RB44:
            Lasttyp 15:
                not active
            Lampendefektbitposition 15:
                0
                0
            Lichtfunktion A 15:
                nicht aktiv
            Lichtfunktion B 15:
                nicht aktiv
            Dimmwert AB 15:
                0
                always
            Lichtfunktion C 15:
                nicht aktiv
            Lichtfunktion D 15:
                nicht aktiv
            Dimmwert CD 15:
                0
                maximize
            Lichtfunktion E 15:
                nicht aktiv
            Lichtfunktion F 15:
                nicht aktiv
            Dimmwert EF 15:
                0
                maximize
            Lichtfunktion G 15:
                nicht aktiv
            Lichtfunktion H 15:
                nicht aktiv
            Dimmwert GH 15:
                0
                maximize
        Leuchte16BLK SLB35BLK SL KC9:
            Lasttyp 16:
                not active
            Lampendefektbitposition 16:
                35
                17
            Lichtfunktion A 16:
                nicht aktiv
            Lichtfunktion B 16:
                nicht aktiv
            Dimmwert AB 16:
                0
                always
            Lichtfunktion C 16:
                Tagfahrlicht
            Lichtfunktion D 16:
                nicht aktiv
            Dimmwert CD 16:
                100
                maximize
            Lichtfunktion E 16:
                nicht aktiv
            Lichtfunktion F 16:
                nicht aktiv
            Dimmwert EF 16:
                0
                maximize
            Lichtfunktion G 16:
                nicht aktiv
            Lichtfunktion H 16:
                nicht aktiv
            Dimmwert GH 16:
                0
                maximize
        Leuchte17TFL R BLK SRB3TFL R BLK SR KC3:
            Lasttyp 17:
                not active
            Lampendefektbitposition 17:
                3f
                19
            Lichtfunktion A 17:
                nicht aktiv
            Lichtfunktion B 17:
                nicht aktiv
            Dimmwert AB 17:
                0
                always
            Lichtfunktion C 17:
                Tagfahrlicht
            Lichtfunktion D 17:
                nicht aktiv
            Dimmwert CD 17:
                100
                maximize
            Lichtfunktion E 17:
                nicht aktiv
            Lichtfunktion F 17:
                nicht aktiv
            Dimmwert EF 17:
                0
                maximize
            Lichtfunktion G 17:
                nicht aktiv
            Lichtfunktion H 17:
                nicht aktiv
            Dimmwert GH 17:
                0
                maximize
        Leuchte18BLK HLA60:
            Lasttyp 18:
                12 - Blinkleuchten
            Lampendefektbitposition 18:
                8
                16
            Lichtfunktion A 18:
            Lichtfunktion B 18:
                nicht aktiv
            Dimmwert AB 18:
                100
                always
            Lichtfunktion C 18:
                Heckdeckel offen
            Lichtfunktion D 18:
                nicht aktiv
            Dimmwert CD 18:
                100
                maximize
            Lichtfunktion E 18:
                nicht aktiv
            Lichtfunktion F 18:
                nicht aktiv
            Dimmwert EF 18:
                0
                maximize
            Lichtfunktion G 18:
                nicht aktiv
            Lichtfunktion H 18:
                nicht aktiv
            Dimmwert GH 18:
                0
                maximize
        Leuchte19BLK HRC31:
            Lasttyp 19:
                12 - Blinkleuchten
            Lampendefektbitposition 19:
                18
                18
            Lichtfunktion A 19:
            Lichtfunktion B 19:
                nicht aktiv
            Dimmwert AB 19:
                100
                always
            Lichtfunktion C 19:
                Heckdeckel offen
            Lichtfunktion D 19:
                nicht aktiv
            Dimmwert CD 19:
                100
                maximize
            Lichtfunktion E 19:
                nicht aktiv
            Lichtfunktion F 19:
                nicht aktiv
            Dimmwert EF 19:
                0
                maximize
            Lichtfunktion G 19:
                nicht aktiv
            Lichtfunktion H 19:
                nicht aktiv
            Dimmwert GH 19:
                0
                maximize
        Leuchte20BR LA71:
            Lasttyp 20:
            Lampendefektbitposition 20:
                9
                39
            Lichtfunktion A 20:
                Bremslicht
            Lichtfunktion B 20:
                nicht aktiv
            Dimmwert AB 20:
                100
                always
            Lichtfunktion C 20:
                nicht aktiv
            Lichtfunktion D 20:
                nicht aktiv
            Dimmwert CD 20:
                0
                maximize
            Lichtfunktion E 20:
            Lichtfunktion F 20:
                nicht aktiv
            Dimmwert EF 20:
                0
                maximize
            Lichtfunktion G 20:
                nicht aktiv
            Lichtfunktion H 20:
                nicht aktiv
            Dimmwert GH 20:
                0
                maximize
        Leuchte21BR RC8:
            Lasttyp 21:
            Lampendefektbitposition 21:
                19
                3a
            Lichtfunktion A 21:
                Bremslicht
            Lichtfunktion B 21:
                nicht aktiv
            Dimmwert AB 21:
                100
                always
            Lichtfunktion C 21:
                nicht aktiv
            Lichtfunktion D 21:
                nicht aktiv
            Dimmwert CD 21:
                0
                maximize
            Lichtfunktion E 21:
            Lichtfunktion F 21:
                nicht aktiv
            Dimmwert EF 21:
                0
                maximize
            Lichtfunktion G 21:
                nicht aktiv
            Lichtfunktion H 21:
                nicht aktiv
            Dimmwert GH 21:
                0
                maximize
        Leuchte22BR MA57:
            Lasttyp 22:
            Lampendefektbitposition 22:
                29
                2c
            Lichtfunktion A 22:
                Bremslicht
            Lichtfunktion B 22:
                nicht aktiv
            Dimmwert AB 22:
                100
                always
            Lichtfunktion C 22:
                nicht aktiv
            Lichtfunktion D 22:
                nicht aktiv
            Dimmwert CD 22:
                0
                maximize
            Lichtfunktion E 22:
                nicht aktiv
            Lichtfunktion F 22:
                nicht aktiv
            Dimmwert EF 22:
                0
                maximize
            Lichtfunktion G 22:
                nicht aktiv
            Lichtfunktion H 22:
                nicht aktiv
            Dimmwert GH 22:
                0
                maximize
        Leuchte23SL HLC10:
            Lasttyp 23:
            Lampendefektbitposition 23:
                a
                29
            Lichtfunktion A 23:
            Lichtfunktion B 23:
            Dimmwert AB 23:
                100
                always
            Lichtfunktion C 23:
            Lichtfunktion D 23:
                nicht aktiv
            Dimmwert CD 23:
                100
                maximize
            Lichtfunktion E 23:
                nicht aktiv
            Lichtfunktion F 23:
                nicht aktiv
            Dimmwert EF 23:
                0
                maximize
            Lichtfunktion G 23:
                nicht aktiv
            Lichtfunktion H 23:
                nicht aktiv
            Dimmwert GH 23:
                0
                maximize
        Leuchte24SL HRA65:
            Lasttyp 24:
            Lampendefektbitposition 24:
                1a
                2a
            Lichtfunktion A 24:
            Lichtfunktion B 24:
                Parklicht rechts
            Dimmwert AB 24:
                100
                always
            Lichtfunktion C 24:
            Lichtfunktion D 24:
                nicht aktiv
            Dimmwert CD 24:
                100
                maximize
            Lichtfunktion E 24:
                nicht aktiv
            Lichtfunktion F 24:
                nicht aktiv
            Dimmwert EF 24:
                0
                maximize
            Lichtfunktion G 24:
                nicht aktiv
            Lichtfunktion H 24:
                nicht aktiv
            Dimmwert GH 24:
                0
                maximize
        Leuchte25KZL HA59:
            Lasttyp 25:
                43 - allgemeine LED
            Lampendefektbitposition 25:
                28
                30
            Lichtfunktion A 25:
            Lichtfunktion B 25:
            Dimmwert AB 25:
                127
                always
            Lichtfunktion C 25:
                nicht aktiv
            Lichtfunktion D 25:
                nicht aktiv
            Dimmwert CD 25:
                0
                maximize
            Lichtfunktion E 25:
                nicht aktiv
            Lichtfunktion F 25:
                nicht aktiv
            Dimmwert EF 25:
                0
                maximize
            Lichtfunktion G 25:
                nicht aktiv
            Lichtfunktion H 25:
                nicht aktiv
            Dimmwert GH 25:
                0
                maximize
        Leuchte26NSL LA72:
            Lasttyp 26:
            Lampendefektbitposition 26:
                c
                2e
            Lichtfunktion A 26:
                Nebelschlusslicht wenn kein Anhaenger gesteckt
            Lichtfunktion B 26:
                nicht aktiv
            Dimmwert AB 26:
                100
                always
            Lichtfunktion C 26:
                nicht aktiv
            Lichtfunktion D 26:
                nicht aktiv
            Dimmwert CD 26:
                0
                maximize
            Lichtfunktion E 26:
                nicht aktiv
            Lichtfunktion F 26:
                nicht aktiv
            Dimmwert EF 26:
                0
                maximize
            Lichtfunktion G 26:
                nicht aktiv
            Lichtfunktion H 26:
                nicht aktiv
            Dimmwert GH 26:
                0
                maximize
        Leuchte27NSL RC6:
            Lasttyp 27:
            Lampendefektbitposition 27:
                1c
                2f
            Lichtfunktion A 27:
                nicht aktiv
            Lichtfunktion B 27:
                nicht aktiv
            Dimmwert AB 27:
                0
                always
            Lichtfunktion C 27:
                nicht aktiv
            Lichtfunktion D 27:
                nicht aktiv
            Dimmwert CD 27:
                0
                maximize
            Lichtfunktion E 27:
                nicht aktiv
            Lichtfunktion F 27:
                nicht aktiv
            Dimmwert EF 27:
                0
                maximize
            Lichtfunktion G 27:
                nicht aktiv
            Lichtfunktion H 27:
                nicht aktiv
            Dimmwert GH 27:
                0
                maximize
        Leuchte28RFL LC11:
            Lasttyp 28:
            Lampendefektbitposition 28:
                b
                31
            Lichtfunktion A 28:
                Rueckfahrlicht
            Lichtfunktion B 28:
                nicht aktiv
            Dimmwert AB 28:
                100
                always
            Lichtfunktion C 28:
                nicht aktiv
            Lichtfunktion D 28:
                nicht aktiv
            Dimmwert CD 28:
                0
                maximize
            Lichtfunktion E 28:
                nicht aktiv
            Lichtfunktion F 28:
                nicht aktiv
            Dimmwert EF 28:
                0
                maximize
            Lichtfunktion G 28:
                nicht aktiv
            Lichtfunktion H 28:
                nicht aktiv
            Dimmwert GH 28:
                0
                maximize
        Leuchte29RFL RA64:
            Lasttyp 29:
            Lampendefektbitposition 29:
                1b
                32
            Lichtfunktion A 29:
                Rueckfahrlicht
            Lichtfunktion B 29:
                nicht aktiv
            Dimmwert AB 29:
                100
                always
            Lichtfunktion C 29:
                nicht aktiv
            Lichtfunktion D 29:
                nicht aktiv
            Dimmwert CD 29:
                0
                maximize
            Lichtfunktion E 29:
                nicht aktiv
            Lichtfunktion F 29:
                nicht aktiv
            Dimmwert EF 29:
                0
                maximize
            Lichtfunktion G 29:
                nicht aktiv
            Lichtfunktion H 29:
                nicht aktiv
            Dimmwert GH 29:
                0
                maximize
        Leuchte30FR LC72:
            Lasttyp 30:
                not active
            Lampendefektbitposition 30:
                0
                0
            Lichtfunktion A 30:
                nicht aktiv
            Lichtfunktion B 30:
                nicht aktiv
            Dimmwert AB 30:
                0
                always
            Lichtfunktion C 30:
                nicht aktiv
            Lichtfunktion D 30:
                nicht aktiv
            Dimmwert CD 30:
                0
                maximize
            Lichtfunktion E 30:
                nicht aktiv
            Lichtfunktion F 30:
                nicht aktiv
            Dimmwert EF 30:
                0
                maximize
            Lichtfunktion G 30:
                nicht aktiv
            Lichtfunktion H 30:
                nicht aktiv
            Dimmwert GH 30:
                0
                maximize
        Leuchte31AMBL 1C61:
            Lasttyp 31:
                not active
            Lampendefektbitposition 31:
                0
                3
            Lichtfunktion A 31:
                Ambientelicht 1
            Lichtfunktion B 31:
                nicht aktiv
            Dimmwert AB 31:
                100
                always
            Lichtfunktion C 31:
                nicht aktiv
            Lichtfunktion D 31:
                nicht aktiv
            Dimmwert CD 31:
                0
                maximize
            Lichtfunktion E 31:
                nicht aktiv
            Lichtfunktion F 31:
                nicht aktiv
            Dimmwert EF 31:
                0
                maximize
            Lichtfunktion G 31:
                nicht aktiv
            Lichtfunktion H 31:
                nicht aktiv
            Dimmwert GH 31:
                0
                maximize
        Leuchte32AMBL 2C35:
            Lasttyp 32:
                not active
            Lampendefektbitposition 32:
                0
                4
            Lichtfunktion A 32:
                Ambientelicht 2
            Lichtfunktion B 32:
                nicht aktiv
            Dimmwert AB 32:
                100
                always
            Lichtfunktion C 32:
                nicht aktiv
            Lichtfunktion D 32:
                nicht aktiv
            Dimmwert CD 32:
                0
                maximize
            Lichtfunktion E 32:
                nicht aktiv
            Lichtfunktion F 32:
                nicht aktiv
            Dimmwert EF 32:
                0
                maximize
            Lichtfunktion G 32:
                nicht aktiv
            Lichtfunktion H 32:
                nicht aktiv
            Dimmwert GH 32:
                0
                maximize
        Leuchte33AMBL 3C36:
            Lasttyp 33:
                not active
            Lampendefektbitposition 33:
                0
                5
            Lichtfunktion A 33:
                Ambientelicht 3
            Lichtfunktion B 33:
                nicht aktiv
            Dimmwert AB 33:
                100
                always
            Lichtfunktion C 33:
                nicht aktiv
            Lichtfunktion D 33:
                nicht aktiv
            Dimmwert CD 33:
                0
                maximize
            Lichtfunktion E 33:
                nicht aktiv
            Lichtfunktion F 33:
                nicht aktiv
            Dimmwert EF 33:
                0
                maximize
            Lichtfunktion G 33:
                nicht aktiv
            Lichtfunktion H 33:
                nicht aktiv
            Dimmwert GH 33:
                0
                maximize
        Leuchte34AMBL 4C37:
            Lasttyp 34:
                not active
            Lampendefektbitposition 34:
                0
                6
            Lichtfunktion A 34:
                Ambientelicht 4
            Lichtfunktion B 34:
                nicht aktiv
            Dimmwert AB 34:
                100
                always
            Lichtfunktion C 34:
                nicht aktiv
            Lichtfunktion D 34:
                nicht aktiv
            Dimmwert CD 34:
                0
                maximize
            Lichtfunktion E 34:
                nicht aktiv
            Lichtfunktion F 34:
                nicht aktiv
            Dimmwert EF 34:
                0
                maximize
            Lichtfunktion G 34:
                nicht aktiv
            Lichtfunktion H 34:
                nicht aktiv
            Dimmwert GH 34:
                0
                maximize
        ambient_lighting_lin_slaves_modules:
            pa_einzeladresse_slave_1:
                0
            pa_verbauinfo_slave_1:
                not installed
            pa_fehlerort_slave_1:
                0
            pa_einzeladresse_slave_2:
                0
            pa_verbauinfo_slave_2:
                not installed
            pa_fehlerort_slave_2:
                0
            pa_einzeladresse_slave_3:
                0
            pa_verbauinfo_slave_3:
                not installed
            pa_fehlerort_slave_3:
                0
            pa_einzeladresse_slave_4:
                0
            pa_verbauinfo_slave_4:
                not installed
            pa_fehlerort_slave_4:
                0
            pa_einzeladresse_slave_5:
                0
            pa_verbauinfo_slave_5:
                not installed
            pa_fehlerort_slave_5:
                0
            pa_einzeladresse_slave_6:
                0
            pa_verbauinfo_slave_6:
                not installed
            pa_fehlerort_slave_6:
                0
            pa_einzeladresse_slave_7:
                0
            pa_verbauinfo_slave_7:
                not installed
            pa_fehlerort_slave_7:
                0
            pa_einzeladresse_slave_8:
                0
            pa_verbauinfo_slave8:
                not installed
            pa_fehlerort_slave8:
                0
            pa_einzeladresse_slave_9:
                0
            pa_verbauinfo_slave_9:
                not installed
            pa_fehlerort_slave_9:
                0
            pa_einzeladresse_slave_10:
                0
            pa_verbauinfo_slave_10:
                not installed
            pa_fehlerort_slave_10:
                0
            pa_einzeladresse_slave_11:
                0
            pa_verbauinfo_slave_11:
                not installed
            pa_fehlerort_slave_11:
                0
            pa_einzeladresse_slave_:12:
                0
            pa_verbauinfo_slave_12:
                not installed
            pa_fehlerort_slave_12:
                0
            pa_einzeladresse_slave_13:
                0
            pa_verbauinfo_slave_13:
                not installed
            pa_fehlerort_slave_13:
                0
            pa_einzeladresse_slave_14:
                0
            pa_verbauinfo_slave_14:
                not installed
            pa_fehlerort_slave_14:
                0
            pa_einzeladresse_slave_15:
                0
            pa_verbauinfo_slave_15:
                not installed
            pa_fehlerort_slave_15:
                0
            pa_einzeladresse_slave_16:
                0
            pa_verbauinfo_slave_16:
                not installed
            pa_fehlerort_slave_16:
                0
            pa_einzeladresse_slave_17:
                0
            pa_verbauinfo_slave_17:
                not installed
            pa_fehlerort_slave_17:
                0
            pa_einzeladresse_slave_18:
                0
            pa_verbauinfo_slave_18:
                not installed
            pa_fehlerort_slave_18:
                0
            pa_einzeladresse_slave_19:
                0
            pa_verbauinfo_slave_19:
                not installed
            pa_fehlerort_slave_19:
                0
            pa_einzeladresse_slave_20:
                0
            pa_verbauinfo_slave_20:
                not installed
            pa_fehlerort_slave_20:
                0
Ug, doesn't help that OBDeleven hides the light functions...
Anyway, I expect these are the front sidelight/DRL channels:
            Lasttyp 4:
            BAP Bitposition 4:
                3a
            Reserved 4:
                0
                43
            Lichtfunktion A 4:
                8
            Lichtfunktion B 4:
                9
            Dimmwert AB 4:
                30
                always
            Lichtfunktion C 4:
                30
            Lichtfunktion D 4:
                0
            Dimmwert CD 4:
                30
                maximize
            Lichtfunktion E 4:
                20
            Lichtfunktion F 4:
                0
            Dimmwert EF 4:
                100
                maximize
            Lichtfunktion G 4:
                0
            Lichtfunktion H 4:
                0
            Dimmwert GH 4:
                0
                maximize
            Lasttyp 5:
            BAP Bitposition 5:
                44
            Reserved 5:
                0
                44
            Lichtfunktion A 5:
                8
            Lichtfunktion B 5:
                10
            Dimmwert AB 5:
                30
                always
            Lichtfunktion C 5:
                30
            Lichtfunktion D 5:
                0
            Dimmwert CD 5:
                30
                maximize
            Lichtfunktion E 5:
                20
            Lichtfunktion F5:
                0
            Dimmwert EF 5:
                100
                maximize
            Lichtfunktion G 5:
                0
            Lichtfunktion H 5:
                0
            Dimmwert GH 5:
                0
                maximize
Based on that, I'd probably try changing the two lasttyp channels to 'general LED'. It might be shown as '43 - allgemeine LED'.
@langers2k Thank you, I'll try it tomorrow. Hopefully it will help.
@langers2k So I tried to change lasttyp 4 & 5 from 9 - allgemeine Glühlampe 27W, auch H15 to 43 - allgemeine LED, but it didn't helped. I also tried to set it to 1 - LED Tagfahrlichtmodul Versorgung, 5 - LED Abblendlicht and 6 - LED Lichtmodul, but same result. Do you have any other idea what else I can try?
Thank you.
Can you give us an update?
Because I'm also interested in changing my DRL halogen to LED.
If you could provide pictures that would be great! :-)
@HaronAshmoz No, still same. I don't have any pictures, but I didn't changed just the bulb in the headlight, I've changed the whole headlight so they now look like OEM Xenon+DRL stripe, but they work with halogen units. So now DRL stripe acts like a H15 bulb, so it's need to be coded to LED.
