Retrofit highline control module
Hi folks,
2011 Octavia VRS petrol, manual,  (facelift)
Recently retrofitted a maxidot cluster and MFSW. I've noticed I've not got all the menus on the maxidot such as lights & visions etc. From some searching I believe this to be due to the convenience control module otherwise known as the body control module. Is this right? Also what is the part number for the correct high line module and is it a simple retrofit?
I've got VCDS but still a newbie with it.
Thanks for any help!
Can you post an autoscan to see what modules etc your car has?
Will have to be later on or tomorrow but I will do
As requested, an autoscan to show the module number. I'm not sure where to look
Thursday,01,April,2021,11:24:58:47023
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBEF21Z3B2087431   License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77 A6
VIN: TMBEF21Z3B2087431   Mileage: 100640km-62534miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
A6-Microphone -- Status: Cannot be reached 1100
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0020
   Revision: AAH18---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 74565 000 00000
   VCID: 79AFE90755D22833C8D-802C
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 163B601C092A0001680F06E7901A0081340800
   Shop #: WSC 62646 004 1048576
   VCID: 75B7E53775CA4C53AC5-8020
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BD    HW: 3T0 907 044 BD
   Component: Climatronic   H16 0402
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 75B7E537754A4C53AC5-8020
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 48000AB8A85BB1C040100080140081E4436000AE525D8960808400040040
   Shop #: WSC 12345 123 61029
   VCID: 38292C032258F13B773-806C
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 08121  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
1 Fault Found:
01134 - Alarm Horn (H12)
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 4
                    Fault Frequency: 40
                    Reset counter: 170
                    Mileage: 100278 km
                    Time Indication: 0
                    Date: 2025.04.02
                    Time: 14:19:50
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.55 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC225ND7
   Coding: 0020788
   Shop #: WSC 73430 790 00088
   VCID: 3D273D17017AD413A45-8068
   Subsystem 1 - Serial number: 6332MSME59010525+
   Subsystem 2 - Serial number: 6342MSME59445A21C
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0180
   Revision: --X01---    Serial number: 20151222100948
   Coding: 1092140000
   Shop #: WSC 36647 001 104857
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 025D8EEB34846BEB997-8056
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Serial number: 2166570
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 943 L    HW: 1Z0 920 943 L
   Component: KOMBI         H04 0406
   Serial number: 00000000000000
   Coding: 710B01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 42DD4EEB7404ABEBD97-8016
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 081210F1002149
   Coding: 351303
   VCID: 30391423CA28297B3F3-8064
2 Faults Found:
00381 - Databus Instrument Cluster
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 207
                    Mileage: 100608 km
                    Time Indication: 0
                    Date: 2025.04.26
                    Time: 06:36:17
03753 - Control Module for Microphone
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 100287 km
                    Time Indication: 0
                    Date: 2025.04.02
                    Time: 16:54:08
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0406
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8DC64B2CF493AB317-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 686 H    HW: 3T0 035 686 H
   Component: RNS-MID       H23 6270
   Revision: AB001001    Serial number: SKZ6Z7P1259701
   Coding: 04000402040100A10000
   VCID: 3B23330F136EDA239A1-806E
   Subsystem 1 - Part No: 3T0 051 859 AT
   Component: EU West V16  8536
2 Faults Found:
02877 - Digital Radio Antenna (R183)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 111
                    Reset counter: 170
                    Mileage: 100280 km
                    Time Indication: 0
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 55
                    Reset counter: 170
                    Mileage: 100287 km
                    Time Indication: 0
                    Date: 2025.04.02
                    Time: 16:53:57
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2120
   Coding: 0000756
   VCID: 48C95CC35EB881BB073-801C
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 313F1127CD22207330D-8064
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 47CB5FFF53A68EC30E9-8012
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
3 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 170
                    Mileage: 100280 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 55
                    Reset counter: 170
                    Mileage: 100287 km
                    Time Indication: 0
                    Date: 2025.04.02
                    Time: 16:53:57
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 100641 km
                    Time Indication: 0
                    Date: 2021.04.01
                    Time: 11:23:46
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012568
   VCID: 323D1E2BC8241B6B497-8066
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33331B2F373E1263421-8066
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660385525
   Coding: 0200000000010110
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 3537253735CA0C536C5-8060
2 Faults Found:
13635840 - Supply voltage
          U1011 00 [000] - Voltage too Low
          [Klemme 30: unterer Grenzwert unterschritten]
          Intermittent - Not Confirmed - Tested Since Memory Clear
13893632 - Function Restricted due to Insufficient Voltage
          U1400 00 [000] - -
Address A6: Microphone
Cannot be reached
End----(Elapsed Time: 01:18, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Your BCM is already a highline so there should be no need to replace it :)
I would try ticking:
- 09 BCM, byte 9, bit 3
It should be 'Multi-Function-Display/Board Computer via Operation and Display Protocol (BAP) active' looking at my notes.
While your connected, I'd would also suggest:
- 19 CAN gateway, installation list, remove A6 Microphone
- Clear all DTC's
Hopefully that'll just leave the alarm siren and the radio (DAB, mic, aux in) fault codes present.
Ok that's interesting haha. Thanks for your help. I know about the fault codes and i'm not fussed as everything works haha.
I'll give that a go a fingers crossed.
Thanks for the extra bit about the microphone, it should still work though if I remove A6 Microphone?
Right that's worked the option is there, now to get the coming home lights working haha
thanks a bunch for your help!!
Yup, the mic will still work with A6 removed.
Basically some cars have a separate module for the mic. The MK2 Octavia doesn't as the mic is either connected to the BT module or radio. This might also be the reason for the mic open circuit code you have :)
Removing A6 from the installation list should resolve the 'cannot be reached' errors shown in your scan.
That's awesome! Thanks again.
Might need further assistance in the future to get the coming home lights working as I don't have the auto lights but so far so good. Never intended to make this a project car but now I can't stop haha
