Karoq 1.5 150hp tyres
Hello there! I am a new owner of a Karoq 1.5 150hp. I want to replace the 215/60/16 tyres with 225/60/16 using the same rims CASTOR 16". Any suggestion??
Thanks!!
9 hours ago, Thodoris said:
I am a new owner of a Karoq 1.5 150hp. I want to replace the 215/60/16 tyres with 225/60/16 using the same rims CASTOR 16". Any suggestions?
CASTOR 16 "light alloy wheel for KAROQ
Rim size: 6.0J x 16 “ET 43
https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-castor-16-pro-karoq/p/57A071496++8Z8
Skoda Karoq 2019 1.5 TSi
– Generation: 2017 .. 2022
– Power: 148 hp | 110 kW | 150 PS
– Engine: DADA, I4, Petrol
– Options: SE, SE L, Ambition, Executive, Style, SportLine
– Center Bore: 57.1 mm
– PCD: 5x112
– Wheel Fasteners: Lug bolts
– Torque: 140 Nm
– Thread Size: M14 x 1.5
– Trim Production: [2017 .. 2020]
Tire
Rim
215/60R16 95V 6Jx16 ET43 2.2
215/55R17 94V 7Jx17 ET45 2.2
https://www.wheel-size.com/size/skoda/karoq/2019/
215/60R16 tyres on narrow 6J rims should give a very comfortable ride, especially if the tyre chosen has soft flexible sidewalls such as all-season tyres from Continental, Goodyear, Michelin, and Vredestein.
For maximum comfort, avoid UHP summer tyres. These tend to have stiff sidewalls for maximum cornering performance at the expensive of ride comfort.
215/60R16 is a really good size for comfort and economy on the Karoq. Notice in the chart above that it says 2.2 Bar (32psi) tyre pressure with this size. If you use 225/60R16 you would need to reduce the tyre pressure by 0.2 Bar (3psi) to get improved ride comfort. However, running lower tyre pressure, ie. 29psi (2 Bar) will make the handling worse.
If you're willing to accept a harder and more uncomfortable ride but with the benefit of sharper steering/handling, then I would suggest 225/60R16 tyres on wider 7Jx16 ET45 rims. This rim specification was fitted to the Yeti and Superb MK2, and there's three rims available called FORREST, MOON, and NEVIS
FORREST, MOON, and NEVIS rims from the Yeti and Superb MK2
https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?q=%3AscoreDesc%3AcarType%3AYeti%2B%282013-2018%29%3AcarType%3AYeti%2B%282009-2014%29
FORREST
Kolo z lehké slitiny FORREST 16" pro YETI
MOON
Kolo z lehké slitiny MOON 16" pro YETI, SUPERB II
NEVIS
Kolo z lehké slitiny NEVIS 16" pro YETI
Edited by Carlston
Thank you so much!!!
Looks like it will be legal (just)!
Speedo must not under read.
https://tiresize.com/comparison/
tom
Edited by Sanqhar
