Touch Screen Clock
I have a Karoq 2018 with the larger screen, Columbus type of unit. I can select through the "settings" app, that when not in use, the screen switches off after 10 seconds and if required, will also show a clockface. On mine, every time I finish a journey, the screen setting for switching off the screen after 10 seconds, reverts back to is unticked, off position. The screen setting (off after 10 seconds) needs to be switched on or reset at the start of each journey.  Is there a way of permanently setting this to remain on? Perhaps using the OBDeleven programming system?
