bolero and RDS
Hi all
i have skoda  kodiaq 2020  with radio Bolero
i need to enable
helps the radio tuner jump between frequencies to find the stronger signal as you move around ( Automatic change of frequency to a regionally linked FM station)
it is not showing  in menu
if any one know how to enable it with VCDS
I thin you may have your terminology mixed up, RDS is Radio Data Systema nd is used for station name, track playing info etc
The feature you're referring to is AF - Auto Frequency
You shouldn't need (and I dont think it can do it anyway) VCDS for this.
taken from the bolero user manual:
Press the button RADIO →   to enter settings menu.
Advanced setup - Sets an alternative frequency and the RDS
■ Alternative frequency (AF) - Search for alternative frequencies of the station currently being listened to on/off
■ Radio Data System (RDS) - Switches on/off the RDS function
■ RDS regional - Switches the automatic tracking of related regional stations on/ off
■ Fixed - Maintains the selected regional station continuously. When the signal is lost, another regional station must be set manually.
■ Automatic - Auto-selects the station with the best reception at the moment If you lose reception the region, the unit will automatically set another available region
Edited by daz1986
