Only Driver Door Opens When Unlocked
Morning all,
Octavia MK III 2020 owner here.
I'm having an issue with the doors on my car.
When unlocked, only the driver door is able to be opened from the outside. Every other door has to be opened from the inside. Once those doors are opened, they function like normal.
Any ideas?
It's a setting you can change using the radio 👍
I think double tapping the unlock button will also unlock everything.
Thanks guys!
Go into the MIB system - CAR -> Settings -> Doors and Locking -> change from Single Door [Driver] to All Doors.
It can be changed, but I prefer it this way; it's actually quite a decent safety feature that only the drivers door unlocks.
But, as above, double press to unlock all.
