catalytic convertor
Can some tell me where the catalytic convertor  is on Skoda vrs  mk2 tdi (07 plate )   as I led to believe it it just after the DPF ... is that correct ...?.
Can any one  tell me if it is possible to clean the catalytic convertor    ? physically remove it and clean ,    would you have to unbolt from the outlet manifolds to gain  access to ?
As far as I know the DPF amd CAT are all part of the first section of exhaust and not independently disassembleable.
I believe your motor is a BMN 2.0tdi for which the exhaust is shown HERE with appropriate part numbers.
grateful ...
