Mk1 Octavia Correct Spring Lenght
So I recently replaced all coil springs for my Octavia, as you can see on the picture the front is higher than the rear. I might have ordered longer springs for the front. I ordered them from autodoc. I wanted all of them to be from SACHS, for front there was more options, but for rear only one. Front - 363mm Rear - 236mm
So can someone tell me what is the correct lenght for the springs?
Thank you.
Do you still have the original springs that you took off?
The sequence of paint colour marks on them are the easiest way to identify the part numbers. There will be a few different possibilities.
No, not least because you get different front springs for the 1.6 petrol, 1.8T and 1.9D engines, since they have different weights, and there is no information in your personal details, your OP, or the picture (nice car though) as to which engine or trim level you have. The RS has shorter springs than the Classic, Ambiante, Elegance or L&K trim levels.
I have them, but even with them the cars front looked higher, so im guessing the previous owner didnt change to correct ones aswell. And now I did the same thing. :laugh:
1.9tdi 66kw 4x4 version, Elegance, year 2001
Skoda Octavia MK1 Estate 1.9 TDI 66kW 4x4
https://web.tecalliance.net/gkn/en/parts/cars/assigned?assemblyGroupId=100113&targetId=12243&typeNumber=12243&groups=188&brands=1&page=0#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20I%20Combi%20(1U5)%201.9%20TDI%204x4;targetType:cars;targetId:12243;typeNumber:12243/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:12243;typeNumber:12243;groups:188;brands:1;page:0
Front Springs 1J0411105AF
Spring Design Coil spring with constant wire diameter
Fitting Position Front Axle
Colour Coding Violet, Yellow
Wire Diameter 12.5 mm
Length 354 mm
Outer diameter 142 mm
Weight 2.15 kg
(1) 1J0411105AF coil spring
for models with heavy duty suspension
1 paint mark
1 paint mark
violet
yellow
Model data: PR-G07/L06
PR-G40/L06
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2001/drive_standart/252/hg_ug/411/subcategory/411005/part_id/2561497/lang/e
Sachs 997616
https://www.ebay.co.uk/itm/223670056870?hash=item3413c637a6:g:dRwAAOSwiQxdgd64
Rear Springs 1J9511115D
Spring Design Mini Block
Fitting Position Rear Axle
Colour Coding Orange (5x)
Wire Diameter 10.3 mm
Wire Diameter 1 16.7 mm
Wire diameter 2 10.3 mm
Length 233 mm
Outer diameter 148 mm
Weight 2.5 kg
1 1J9511115D coil spring
5 paint marks
orange
Model data: KOMBI
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2001/drive_standart/252/hg_ug/511/subcategory/511015/part_id/2561497/lang/e
Sachs 994196
https://www.ebay.co.uk/itm/224174529422?hash=item3431d7db8e:g:ig8AAOSwa4xde0fw
Edited by Carlston
