RCD330 & Gateway Upgrade - Octavia 2007 VRS
Evening All,
As put in the title I want to change the Stream radio to a RCD330 in my Octavia VRS Estate 2007. I have read close to 100 posts/articles/videos about it and have narrowed the process down - there are jus at a few queries.
1. Buy RCD330 unit (easy)
2. Buy new Fascia
2. Buy Upgraded Gateway . . . . .
Is there a specific number the 07 Octavias were given so I can just search for the updated one or do I have to look at my specific unit to then order the correct upgrade? For example all the models on ebay I found for Octavia 2007 are - 1K0 907 530 then the 'L-AA' Is this correct?
3. The garage will be coding it for me so does it matter what number gateway I get (Apart from making sure its 'L' or higher)
After that I am going to assume all is going to go smoothly!
Final thoughts - Are there any better stereos suitable now? All I can find are Xtrons which are quite expensive and the usual suspects from Halfords.
I fitted 1K0907530S to mine and it programmed good.
I think you're just looking for the age of part being newer than the Octavia.
