Exhaust Temperature Sensors
Waiting for the car to go into the garage to have a replacement EGR valve fitted and a check on the DPF as it very quickly 'blocks' and requires a very regular service regeneration and always appears to be attempting a passive regeneration, rise in tick over speed to approx 1000 rpm and fans continue to run after switching off. Last couple of times taken it for a good blast down the motorway then be able to carry out a service regeneration no problem, but if I just take it for a run around to get it up to temperature it's not so easy. Took a snap shot as it was regenerating earlier today and have a query about the Exhaust Sensors. It's a 2.0 Tdi CR CFCH engine. 4 sensors are listed, 3 seem to be well up to temperature while No 2 reads 0? Anybody know if this is normal and if it actually has 4 sensors? There are no fault codes listed on any scan done.
Tuesday,06,July,2021,15:08:50:08428
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBGE21Z7C2140161 License Plate: YR12 FEP
Mileage: 195913 Repair Order:
Address 01: Engine (03L 906 018 C)
15:08:24
IDE00433 Particle filter: oil ash volume 0.00 l
IDE00434 Particle filter: soot mass calculated 1.12 g
IDE00435 Particle filter: soot mass measured 5.43 g
IDE02229 Exhaust gas temperature sensor 1 649.7 °C
IDE02233 Exhaust gas temperature sensor 2 -0.0 °C
IDE02234 Exhaust gas temperature sensor 3 531.6 °C
IDE02236 Exhaust gas temperature sensor 4 667.8 °C
2012 Skoda Octavia II Estate 2.0Tdi 140PS Manual
2015 Skoda Octavia III Estate 2.0Tdi 4 x 4 150PS Manual
2017 VW Sharan 2.0Tdi SE Bluemotion 163PS Manual
2019 Seat Alhanbra 2.0Tdi LUX Ecomotive 150PS Manual
Yup, it's normal for a CFHC engine not to have temp sensor 2 fitted :)
More confusing for me is that your oil ash volume is 0.00 l. It should be considerably higher than that in a car with 196k...
