Oil level fault codes
I get these 2 codes.
00562 Sensor for Oil Level / Temperature (G266)
P0196 Engine Oil Temperature Sensor (G8), Implausible Signal
Is this the oil level sensor on the bottom of the sump or the oil pressure sensor on the side of the block?
Maybe the oil level sensor needs cleaned?
  • Sponsor
Sump sensor. As the first code says, it's a combined level and temperature sensor.
I'm thinking wiring problem is more likely. Check for contamination inside the loom connector, and wiring damage nearby or wherever it looks exposed and vulnerable.
If you were to give us a clue about year of car and and engine type (engine code ideally) we might be able to be more specific about wiring.
