Rear seat electrical connections
Two photos of the Karoq Vario Flex rear seat electrical connections.
One shows the floor pan with the nearside seat connections (the double block of which only one is used on my Karoq) and the red warning triangle flap cover for the centre seat.
Why does only the centre seat have a flip over red triangle warning flap?
As you can seat one part of the cover for the nearside seat has got broken, probably by the heavy seat being dropped on it in the wrong position.  The second photo shows the missing part which has broken into 2.  Is this small flap available as a spare part?  It has the following moulded in - >PBT-GF20< and 10138397?
If not available, your suggestion(s) please as to which type of glue could be used to glue another plastic strip across the back or the front to hold the 2 parts together.
Because the side seats are usually in position in either of two connectors and cover the others. They have automatic dirt covers which cover the connectorwhen not in use.
The middle seat can be left out and the connector is then accessible to those in the side rear seats such as children’s hence needs a more robust cover with a warning.
Don’t forget to open it when dropping the central seat base as I think it would break easily!
Edited by kenfowler3966
  • 2 years later...
Hi
Did you ever find a part number for the broken flap ?
On 07/09/2023 at 12:06, Williami33 said:
Hi
No - I did not go looking for a part.  And currently the flap is as shown in the photos.
Brampton Trev , thanks for your reply ,
Does anyone know the part number for this  flaps?
One way used with motorcycle plastics is to form a zig zag with a paperclip, lay it on and 'melt' it in by pushing it down with a soldering iron.  Another way is to 'weld' it by using a soldering iron with a zip tie as the welding rod.
There are many  videos on YouTube, this is but one as an example:
...just search "plastic repair" (without the quotes)
tom
Does anybody know if it’s easy to replace the cover as mine is broken?
Hi Mike
If it is the spring loaded flaps that are broken then you need to get the whole connector as I found out ,  the flaps are easy to swap across to replace the  broken one’s
To replace the whole connector is slightly more difficult as you have to take out a lot of the interior to get to it
Regards
Will
On 02/11/2023 at 18:48, Williami33 said:
Hi Mike
Regards
Will
Hi Will,
How did you manage to swap out the flaps? I've got a new connector and I'm unsure how to take out the flaps as the pin looks very very tight?
Regards
Mike
  • 4 weeks later...
Hi Mike
Sorry just seen this , did you manage to swap out the flaps ?
I just raised the middle slightly until they popped out then manipulated them again in the  middle to pop them back in
Regards
Will
