After fitting new steering wheel control module, cruise stalk now "faulty"
Hi all,
I've recently fitted MFSW and the Steering Wheel Control Module which works with the RCD330 and the steering angle sensor.
The only thing that has decided not to work is the cruise control, despite me having it selected in the steering module.
Has anyone experienced this before? Cruise worked fine before changing this module.
My only "solution" is to remove the MFSW and go back to how the car was originally as I'd rather have cruise than MFSW.
I can get a VCDS log in around an hour.
year?
model?
parts used?
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN:    Mileage: 212260km-131892miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 LB
   Component: R4 1,9L EDC G000SG  8501
   Revision: --H02---    Serial number: SKZ7Z0F3662083
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 6ADB77AF457FE0D6AD-803E
2 Faults Found:
001384 - Cruise Control Switch (E45)
               P0568 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 212262 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:28:13
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.39 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 212262 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:28:13
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.39 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8DF6FB6E7DB57E2A-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B7582EB7A65A95E06-806E
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004252378
   Coding: 418A0F030004140000110D000000000000087F075C
   VCID: 2B55B2AB8A0539DE96-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     220606 014  1201
   Coding: 00471077
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0KNUTM
   Coding: 0020788
   VCID: 3D718CF36471A76E38-8068
   Subsystem 1 - Serial number: 6332MSME10504D6FF
   Subsystem 2 - Serial number: 6342MSME10745B088
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0000133
   Shop #: WSC 12345 123 12345
   VCID: 7AFB47EF35DF50565D-802E
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
1 Fault Found:
00895 - Cruise Control Switch (E45)
            014 - Defective
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 D    HW: 1Z0 920 912 D
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610036    Serial number: SKZ7Z0F3662083
   Coding: 0007401
   Shop #: WSC 28061 210 61833
   VCID: 366393DF41477436F9-8062
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 34000000000000
   Coding: E9807F0E000202004301
   VCID: 377D9EDB464D8D3EE2-8062
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000758
   VCID: 387F9DE74B538246EB-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 356194D35C417F2EF0-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 01801A085283007F3F04850540085F96907CA0
   VCID: 03053A0B4215119E0E-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0934
   Coding: 0000758
   VCID: 397998E370599B4E14-806C
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5538
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 0E000400040005
   Shop #: WSC 127395 840 08317
   VCID: 4683E31FF1A7E4B669-8012
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 212262 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:28:14
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0905
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
To stop battery drain on RCD330 headunit I fitted a later gateway module.
To get the steering wheel buttons to work I changed the steering wheel control module.
Now everything works but getting the cruise fault.
It's possible the pin layout is different and the steering control module doesn't see the cruise as in later cars it had its own stalk
Have you checked the Ross Tech page for fault diagnosis?
http://wiki.ross-tech.com/wiki/index.php/16952/P0568/001384
Also if you let us know the year & model of the car and part numbers of previous components used it may assist in answers being provided.
Have you checked all of the wiring plugs have been correctly seated? It could be as simple as something not plugged in correctly.
The pin layout on 1K0953549CH is different to the original, specifically the cables going to the stalk. I have just refitted the original control module and alas, cruise works again.
So now I'm wondering does the SW matter? I think perhaps my module is for cars with the standalone cruise stalk.
It's difficult to find highline modules for this, hence opting for CH as they're easy to buy.
