Advice needed - Replacing driver's door lock 98 SLXi?
Some months ago I had a central locking problem diagnosed as needing a new door lock. Now I have finally got around to buying the new lock, I need some advice on fitting it.
Can anyone point me to a simple step-by-step guide? I can handle a screwdriver and a socket set but my skills don't go much further than that!
Thanks.
Tony
There isnt a step by step guide, but I can give a quick how to.
Remove door trim
Remove door key barrell
Remove inner plastic membrane (needs to be refiitted with no holes)
Unbolt the lock
Refit is reversal
Anything you struggle on give us a shout.
Thanks Lummox - will let you know if I need any further help.
