Help vrs pfl 2.0
Headlight,indicator,side light and fog light not working on driverside and driverside rear indicator
Is this a fuse or relay
2008 pfl mk2 octavia vrs petrol
Fuse diagram in booklet is wrong
Anyone got photo of fuse layout in 2008 vrs petrol manual octavia
Both under bonnet and driver door fuse boxes
The fuse diagram on the back of the dashboard end cover will be mostly right BUT it is a mirror image as it was created for LHD cars.
I find the best way is to sit sideways on the drivers' seat holding the diagram above your right knee. Then glance between the diagram and the fuses while counting fuse locations from front to back.
Headlight fuses may be in the fuse box by the battery.
No diagram on fuse box covers unfortunately
