Fabia VRS TDi Heli-coil front brake carrier to hub axle bolt
Superb pictorial! Had to do this exact same job earlier this year. Stripped my threads due to stupidly getting mixed up with 'lefty-loosey & righty-tighty' from behind.
Sure your post will help others, oh! and welcome to Briskoda.
I havn't stripped any of the threads yet but I did buy a Ford, VAG & Vauxhall repair kit very cheap on Ebay which was recommended on this forum, it comes with drilling jigs set to the hole centres of the various manufacturers which will prevent or mitigate against misalignment from the drill bit snatching.
The inserts are a splined Top Hat type so are pulled into place against their shoulder by the caliper bolts & will pull up square against a small misalignment, a lot easier to use than Helicoils as well and no risk of them unwinding.
JR- my local machine shop tells me that VAG carriers are his best quick money job. But I've vnoticed that on 05 models the allen bolt has been replaced with a standard nut. Mine had a "35 point check, and I suspect pad change" at a well known place prior to sale. 75k miles later and no problems .
