Heater Blower Replacement
I have the famous squeak and sometimes cut out from the heater blower.
No big deal 15 min fix but the options out there for parts range from £50 to £150 for a Valeo which is the original in the car.
Is there really that big of a diffrence ??? What would you do???
Part Number 1K2820015G
Thanks in advance
Buy used cheap, buy aftermarket more, buy Valeo morer.
Personally I'd just put a new set of brushes in the motor.
A quick search reveals a few have had success giving the bush(s) a good squirt of WD-40 or similar and lived happily ever after.
Edited by MicMac
@MicMac
Ok this would stop the motor when its cust out. But is this even possibly is the unit not sealed?
I thought about doing this but then thought all I would do is have a constanst smell of WD40 in the cab.
28 minutes ago, MRB007 said:
@MicMac
I don't know.
You haven't used WD-40 much have you...
Plenty what makes you say that?
The bouquet dissipates in a few days.
Does anyone know what brushes fir the factory motor?
If nobody chimes in just measure the old ones, buy cheap online and cut to size.
