Ctek permanent charge lead indicator
With the ctek charge lead indicator it says to plug into positive and negative, then on the LED indicator it shows your battery state.
When charging though the negative should be on positive and chassis bit for the negative, does that mean the battery indicator wouldn’t work?
Also for people who have the normal charge lead, is it m6 or m8 required (I could look admittedly…)
Edited by Danoid
  • Danoid changed the title to Ctek permanent charge lead indicator
Do not put the negative lead on the positive!
if done correctly the indicator will still work no problem
Oh em gee, no idea why I wrote negative on positive 😬, can’t edit the post now either.
Do you know if it’s m6 or m8 on the battery terminal and chassis terminal?
