anyone play music from a USB stick?
I find the navigation between albums a bit inconsistent. Sometimes you can swipe through the different albums on the stick with the album art, other times it doesn't let me do that and I don't understand why. Also sometimes only 3 albums show when I have over 50 on the stick. If I unplug and plug it in again they all show.
Are all the songs in the exact same format?. Are there only those songs on the UBS stick?? Are the files they are in as few as possible??
Each album is in its own folder. Most are individual track flac files with the odd MP3.
Hey @mccririck,
I am still persisting with a usb stick for my music. I seem to get away with having a mix of *.m4a (straight from itunes) and good old *.mp3. I also found that the system didn't see music that sat within subfolders - but that might be a quirk of my system or even me! itunes loves putting everything in subfolders. Since I removed sub folders, removed non-playable formats e.g pdfs, mpeg-4 and added album artwork, I seem to have solved everything, but time will tell!
You could try some of the above tricks, see if that helps? I couldn't find a supported files list, so I just did guesswork.
Not sure if that's helped, but hopefully a few things you could try?
I am sure there is a post on the forum that covers a lot of this, but I couldn't find it. Maybe one of the longer standing members will be able to throw a link over. However, I think a lot of people just use their phone these days and that removes most, if not all of these issues.
Cheers, Scotty.
No real point in FLAC in the car...I just use 320kbps fixed rate MP3 for the car.....FLAC I use for home audio...
Sometimes a combination of different file types on the same stick is enough to confuse the systems...
Hmm, it was never a problem in my 2017 Seat Leon. I prefer just putting FLAC files in the USB as that's how I store my music on my computer. It works fine sometimes in the Skoda and other times the touch on the album art for scrolling doesn't work.
I use dbpoweramp to rip my CDs as FLAC...& then batch convert to MP3 from FLAC..
Yes I know I'm using a MIB I Discovery sat nav with Dynaudio, but the basics behind it are the same across the MQB platforms....not had any problems..only the occasional missing album art if I've just reloaded the SD card (all music on an SD card in the glovebox) & not done a head unit reset..
I dont see the point in converting to mp3 as the car can play flac.
Mine doesn't do FLAC..even if it did I would still not use FLAC in the car..can't hear the difference in 320kbps -vs- FLAC in the car even with the Dynaudio...well its not the best environment to do so anyway!
Also by using fixed 320kbps MP3 the files take up way less space than full FLAC so can fit more on the SD card..
All MP3 (over 100) only problem I have is variations in volume between tracks.
That's probably down to them being mastered differently, some will have a lot of compression added and some will be more dynamic but therefore have a lower average volume.
There's surely no harm in using FLAC if it can process FLAC. And storage media are big enough nowadays that you don't really need to use mp3 to save space.
Edited by mccririck
Is it a problem that can be overcome? I use Mediamonkey v4.2
What do you mean?
Can the MP3 be changed, perhaps to FLAC or evened out for volume?
