Heater Fan
Sorry if this has been asked before.
Got a new Octavia vRS on Friday & the interior heater fan has stopped working today (Sunday).
The light on the recycle air switch doesn't light now either.
If anyone has any ideas before I ring tomorrow I would be very grateful
Check the fuse.
The recycle won't work if the direction is to the windscreen.
Does the heater fan work at any of its speeds? I had a similar problem from new with the fan only working at its high setting ie 4. Turned out the rheostat was defective. Easily fixed 1/2 hour job on warranty :)
Thanks for the replies.
First thing I checked was the fuses.
It was working again briefly this morning - I suspect a loose connection.
Its booked in first thing tomorrow.
The recycle not working when it's directed in any direction & started working again & then stopped at the same time as the fan.
Anyway should be sorted tomorrow.
Thanks again for the replies.
