Reset user profile in Bluetooth module using vcds
Hi
I am new to vcds and bought a Skoda Superb 3T4 second hand. My bluetooth module(7P6 035 730K) is already paired with 4 devices and i am unable to delete the old users through MID. In group 77 Telephone under Adaptations the option to reset/ Erase user profile is there but when i do it a message pops up which says no response from subnet component. Do i need the security access for the module to do the same? If yes then can someone help me with the security access code. Any help would be appreciated as this issue is bugging me for a long time. Posting my autoscan for reference
Code:
Tuesday,25,January,2022,18:30:36:56012
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: TMBBEM3T5CA------   License Plate:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 36 42 44 46 52 55 56
          62 72 77
VIN: TMBBEM3T5CA------   Mileage: 168640km-104788miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CLJA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JD    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H25 9977
   Revision: 42H25---    Serial number:                CVN: EA2844DC
   Coding: 001D0012042500080000
   Shop #: WSC 10016 663 00000
   ASAM Dataset: EV_ECM20TDI01103L906018JD 003005
   ROD: EV_ECM20TDI01103L906018JD.rod
   VCID: 75B4E859454C9A63847-8020
   VINID: 91D49255D0E41534430012031C3D95BA07
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3520
   Revision: 05551213    Serial number: 00001209060336
   Coding: 0000020
   Shop #: WSC 33361 790 00999
   VCID: 2412E51DB2D653EBE39-8070
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 863D6016092200FB611306E790200082350000
   Shop #: WSC 33361 790 00074
   VCID: 7DA4F0797DFCC223CC7-8028
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0185339423
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02013
   ROD: EV_KESSYPQ35G_A02_VW31.rod
   VCID: 3432155D0EB6C36B739-8060
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000001002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 7CA2FD7D6666CB2BFB9-8028
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AG    HW: 1K0 937 087 AG
   Component: BCM PQ35  H+  111 0709
   Revision: AC111709
   Coding: 46990ABBE85BF1C040080080310089E4417100AE772081F05C804000A040
   VCID: 76B6EF5558CA917B8DD-8022
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 22061  26  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 220912 05  54  0403
   Coding: 0630ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 168641 km
                    Time Indication: 0
                    Date: 2016.06.17
                    Time: 18:28:48
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.95 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28261224304233
   Coding: 108104
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000_001.rod
   VCID: 43D046815B1874D3FA3-8016
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LBY VW10 HI   2118
   Revision: 22017000    Serial number: 003LEPBZLCFS
   Coding: 0016985
   VCID: 42DE438548827DDBF15-8016
   Subsystem 1 - Serial number: 6332MTS632141902
   Subsystem 2 - Serial number: 6342MTS601081639
   Subsystem 3 - Serial number: 6351HTS6C4KI4BKJ
   Subsystem 4 - Serial number: 6361HTS67FMI4BKR
   Subsystem 5 - Serial number: 63727TS64A482BKJ
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010041    Serial number: 20120818301068
   Coding: 001A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA4F0797D7CC223CC7-8028
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 3T2 920 841 K    HW: 3T2 920 841 K
   Component: KOMBI         H06 0608
   Coding: 110F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3C223D7D26E60B2BBB9-8068
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 180912F1001938
   Coding: 353303
   Shop #: WSC 33361 790 00000
   VCID: 3FD84A71377010339EB-806A
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8ECB251CF2459B195-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000208483004
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F381A31E790E0B30EB-807A
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 C    HW: 3C8 959 760 C
   Component: Sitzmemory    H05 2901
   Revision: 00H05000
   Coding: 000039
   Shop #: WSC 12336 024 394758
   VCID: 35342859054CDA63447-8060
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE01001000
   VCID: 52FE73C594E2ED5B415-8006
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 196    3305
   Revision: 00H22000
   VCID: 372822511340287356B-8062
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51FC7CC991E4964378F-8004
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1377095
   VCID: 3432155D0236C36B739-8060
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000021
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 156 C    HW: 3T0 035 156 C
   Component: BOLERO        013 0029
   Revision: -----27S    Serial number: SKZ4Z3K1104612
   Coding: 0D0004000004
   Shop #: WSC 33361 790 00081
   VCID: 2E060735E01AE9BB05D-807A
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H07 0415
   Coding: 010C00200001001000
   VCID: 50FA79CD9AEE9F4B771-8004
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H07 0415
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663554302
   Coding: 0200000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2E3B652CD2351BA95-806E
End----(Elapsed Time: 01:32, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
