Ambient lighting retrofit coding help please
Hi All,
I have a 2016 Superb 2.0 cr tdi, it "was" an SE but I have spent a lot of time and money retrofitting all sorts of goodies. I now need a little help as I am now stumped.
Retrofitting and coding isn't something I am new to, I have carried out a lot of retrofits over the years.
I have installed the L&K rgb ambient light strips in all 4 doors and along the dash and wired them in, with a little help from a guy called Cryptgod we have them working.
I then decided to add the 4x footwell lights. A little tinkering in ODIS-E and I have them working.... BUT...
I cannot adjust the brightness in the headunit by selecting "Footwell" only with "All Zones", I have tried everything I can think of, but getting no where. I have even flashed my BCM from CG to CQ.
I have also noticed that the footwell lights at full brightness really are not bright enough. Is there some coding somewhere that will increase the output to them?
i am running the 30 colour palette.
Thanks all.
For those of you that may be interested, I have the following retrofits and mods. (I also have ODIS, ODIS-E and GeKo access).
L&K 17" Wheels,
L&K Full leather memory and heated front and rear seats,
L&K Full RGB Ambient lighting - in progress,
MIB 2.5 with 9.2" display, with latest maps, dab, bluetooth, Business Telephone interface with sim card, Car play, android auto,
High Reverse camera with parking assist, dynamic lines and wash function.
Touch climate control,
Virtual Cockpit
Heated windscreen with fully coded, calibrated and functioning lane assist camera,
High beam assist.
EGR and DPF delete using Darkside development kit.
Have you compared your admap so a factory admap that has what you are after?
what’s the differences?
No I haven't, not found one and don't actually know where to find that.
Sadly cant help out, as i havent done mine, but wondering where you found the hardware, i am on a look out for the trims with rgb, cant seem to find it, what i did find was the "wooden look" ones, and i need the "aluminium" ones! Thank you! And have you thought about colled/ventilated front seats?
