Headlight Projector Lens Cleaning
Hi All,
Been suffering with poor headlights recently, even with upgraded Halogens and a set of LEDs, read somewhere on here that the projector lens may look clean but is in fact quite dirty.
Anyway, method I used to clean them which has worked a treat is to remove the headlight assembly, remove the bulb and blast the back of the lens with electrical contact cleaner followed by a 1" paint brush shoved down the hole so all the bristles spread out, this can then be spun around to clean the whole lens. Quick blow out with the compressor and jobs a gooden.
Hope this is of use to someone...
Dan
