2009 Skoda Fabia 1.9 Diesel Electrical?? Issue
Hi everyone - I have an issue with my trusty & ultra relaible 2009 Skoda Fabia 1.9 Diesel.
All of a sudden (no rhymn nor reason to this) all the warning lights come on the dash (you can be driving or not) and you loose power brakes, steering, air bag waning light comes on, etc).
Ignition off & back on and the cer behaves as you'd expect - but the AirBag light remains on.
Here is a copy of the AutoScan
ednesday,22,December,2021,19:25:00:15721
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: TMBDG65J193107054   License Plate:
Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBDG65J193107054   Mileage: 281020km-174617miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 NS
   Component: 1,9l R4 EDC G400SG  0984
   Coding: 00102
   Shop #: WSC 00186
   VCID: 75E5DBCA4FFC5F2162-4B00
   TMBDG65J193107054     SKZ7Z0H5188603
1 Fault Found:
18058 - Powertrain Data Bus
            P1650 - 35-00 - Missing Message from Instrument Cluster
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6R0 907 379 J    HW: 6R0 907 379 J
   Component: ABS 8.0 front   H06 0003
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002193
   Shop #: WSC 13765 790 00000
   VCID: 45856B0A0F9C8FA132-513C
No fault code found.
Address 08: Auto HVAC        Labels: 6Q0-907-044.lbl
   Part No: 5J0 907 044 A
   Component: CLIMAtronic SK25    0608
   Shop #: WSC 00000 000 00000
   VCID: 285BC2BE98CE72C929-513C
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 13765
   VCID: 3E7704E63A4ADC7973-5120
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            49-10 - No Communications - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: QA AIRBAG VW61 Q5Q6 0004
   Coding: 20801
   Shop #: WSC 13765
   VCID: 2759C182C5D07DB120-5120
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 941 C
   Component: KOMBIINSTR.    V2802496
   Coding: 19404
   Shop #: WSC 41051
   VCID: 2B513DB2D93859D1C4-513C
5 Faults Found:
01314 - Engine Control Module
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
00457 - Central Electronics Control Module / BCM (J519)
01309 - Power Steering Control Module (J500)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.clb
   Part No: 6N0 909 901
   Component: 000G GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70EBEADE309E7A09B1-513C
1 Fault Found:
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2802496
   Coding: 19404
   Shop #: WSC 41051
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10110
   Shop #: WSC 13765
   VCID: 6DD5F3AA27AC97E19A-513C
1 Fault Found:
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 5J0 959 433 A
   Component: 05 Komfortgerát     0001
   Coding: 00018
   Shop #: WSC 13765
   VCID: 316D2FDAFB143301FE-4B00
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5J0 035 161 A    HW: 5J0 035 161 A
   Component: Radio         005 Radio         005 00130013
   Revision: R0005000    Serial number: SKZAZ4H7543329
   Coding: 05000400000600
   VCID: 204BDA9E30FE8A8961-5120
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 76: Park Assist        Labels: 5J0-919-283.lbl
   Part No: 5J0 919 283
   Component: Einparkhilfe        V005
   Revision: 00012000    Serial number: 08091083641724
   Coding: 0001120
   VCID: 6FE9E9A27DA065F1A8-5120
End-------------------------(Elapsed Time: 04:14)--------------------------
New car electronics are not my strong point, so wanted to pick the combined brain of the hive mind to see if you can assist me in rectifyiing this fault.
Many thanks
Mark
