Epc Light On Fabia 1.4mpi
Hello
I have problem with EPC light on my FABIA 1.4 MPI
The problem is following: EPC light is ON.
I have been in
Are they fitting the brake light switch properly, if not fitted correctly its quite easy to break.
Are your brake light bulbs ok?
I must admit, that after they mounted break switch, I noticed that my breake pedal is little move on the left.
Now I have not enough space to pull down the speed pedal.
Do your brake lights work as they should?
Yes, the breake light work properly all the time
