Black Cable under LH Dash
Hi All
After repairing my Fan Blower I foolishly left a thin black wire (possible an earth of some kind) loose. It has since become detached from the RH end of where it connected.
I do not even have any idea what it relates to, so anyone out there. Mine is a 2013 4x4 Estate (Diesel).
You don't say the trim level, so I guessed Elegance.
According to this diagram, the black wire from the  pin blower plug goes off to the sunroof solar panel.  Do you have a sunroof solar panel thingy?
If not, please state if you have climatronic (the automatic temperature one) or climatic (the manual temperature one).
I've included the 2nd diagram for climatic, but the blower doesn't seem to have a black wire there.
Thanks for detailed reply. I do not have a sun roof solar panel. The Car is the Elegance and does have the Climatronic, I belive it to be the automtic variety.
Hi Nick, not sure then, the first diagram should apply but it wouldn't be the first time the documentation is wrong.
Do you have any more information on where the wire goes to?  I.e to a plug, and if so, how many connector pins in the plug?
A VCDS or VAS scan would probably tell you if it was important as you'd see a module report either an open or missing or implausible signal.
