Remove C pillar and D on Combi\Estate
Hello, i need to replace the aerial amplifiers of my skoda supeb 3 estate, i know they are under the headliner on the boot side windows. What is the easiest way to get them out.
can anyone share some pictures of how to remove the pillars and the spot where the amplifiers are ?
Thank you
Škoda Superb III C PILLAR.pdf Škoda Superb III D PILLAR.pdf
There are amplifiers on the side windows and the rear window, you sure you know which one needs replacing?
remove the d pillar is just a pop off job.
removing the c pillar involved removing the boot side trim - the plastic upper part, not the lower fabric part
I need the rear ones, both of them, 4 and 6 in the pdf below.
Škoda Superb III - rear amp.pdf
Today i removed d pillards it was easy just like you said, but to my admiration there was no amplifiers there. I want to put the tv Turner amplifier i think t its theire place or am i missing something ?
ah, for tv tuner you remove the black one and fit the yellow ones i assume you have, there are 3 of them and 1 is in the tailgate also.
I believe the side window amplifiers are in the top of the frame under the headliner.
I don't have none of them, i assume it is because i don't have dab. I know i need to solder the conection to the side window , i just don't know where to pin them, and i dont know witch of the two conection on the amplifier  i should connect the tv aerial cable.
